I acquired a Phoenix 8
Here are some photos of a P-8 i acquired. The plane is in very good condition, i see some hanger rash and campaign scars but i'm happy. This is one of the planes that John Gaylord offered for sale. Now to remove the old servos, battery and receiver. Any pointers on connecting the kraft retracts to a modern receiver? Also the engine is a piped Webra, a 1st for me. Hopefully the seller will clue me in on the engine's condition.
RE: I acquired a Phoenix 8
Looks good David.
I see a flying stab!!
I can’t wait for you to get her in the air and give us some feedback on that mechanism.
Can you see in the tail at the unit?
i've had the plane for a week and just unpacked it. didn't even know until today that it had a flying stab. i do know it doesn't move much but i have not looked at the mechanism yet.
John had the plane professionally boxed for $60 or $65, greyhound charged $50 to send it to the nearest station to me. unfortunately the box was too large and had to be abandoned. it was a box worth keeping.
i am very curious about the flying stab also, so i will try to do some research and post it here.
does anyone have any advice on connecting kraft electric retracts to modern equipment? i have stripped the old kraft receivers and servos out of the phoenix and starting to replace with new equipment. around 24 oz of old equipment and batteries came out.
My Feedback: (8)
Nice looking airplane there!
I asked that question (about using Kraft Multicons with a modern Rx ) a few years ago, and was told that all I had to do was change the connector on the amplifier.
You should have a seperate little gold amplifier box, with three x 2 wire (red and black ) leads/2 pin connectors that plug into the gear units...
There should also be 1, 3 wire connector, that would plug into ch. 5 in the Rx....change that connector.
Cover My ***** here...I've never actually done it yet though...so I'm not 100% sure it's gonna work.
ok so the amplifier has three 2 wire strands and one 4 wire strand. the 2 wire strands are labeled a. pwr, b. nose ret, and c. rx aux. the label on the 4 wire strand is unreadable. the green tabs are my own markings, just in case.
My Feedback: (8)
Hmmm....I wonder if there are 2 versions of the amp? IIRC my channel 5 connector only has 3 wires? (I guess I'll have to dig it out and check...I could be wrong ) I bought my set of Multicons from Tower in '76 or '77.
The three connectors with only 2 pins/wires are to the mains and nose gear...the one with 4 wires plugs into the retract ch. of your rx.
Someone with a bit more knowlege of older radio systems will have to tell us which wire to ignore. The red and black are obvious...and I think the orange wire is the signal wire, but I will defer to someone who can tell us for sure.
You might want to consider a different set of retracts though...at least the nose gear, as they can be unreliable.
Inside the retract is a wiper that wipes/contacts on a circuit board track...and since the nose gear is right up against the firewall (usually ) the engine vibration really does a number on the circuit board/wiper assy. and the nose gear becomes intermittant, then quits working...seen it happen a couple times and heard of it happening a few more.
QC, CANADA
Gents,
I can explain this. I'll gather some photos and post them tomorrow. In a nutshell though, yes, they can be connected - in several different ways. And yes, there are several different amps depending on the Multicon vintage. The amps are actually armless servos - you'll notice they look much like the Kraft servos. They serve as a polarity trigger. The system is double throw/double pole (DTDP).
More tomorrow.
David.
More tomorrow.
David.
ORIGINAL: proptop
i'll probably leave the retracts in at the moment. i don't expect to fly the plane a lot. but i do have sets of spring air retracts waiting to be used.
ORIGINAL: dhal22
MattK
QC, CANADA
David,
something doesn't quite jive between those small Kraft wheels (2"?) and the wells. One has to grow or the other shrink.
More on Multicons later.
David.
David.
David, I read your first post:
What type of Webra is that?
Cees
Cees
ORIGINAL: dhal22
"Friends don't let friends wreck classic airplanes with stupid retracts"
-Robert
ORIGINAL: doxilia
David,
something doesn't quite jive between those small Kraft wheels (2''?) and the wells. One has to grow or the other shrink.
David.
David,
David.
david, you don't like those tiny wheels?
i will label the amplifier wiring a bit better:
one of the 2 wire assemblies is labeled nose ret
another one says pwr
the 3rd 2 wire assembly says rx aux
and the 4 wire assembly marking is illegible
ORIGINAL: Taurus Flyer
Cees
Cees
the plane was stored in competition condition in '82 (i think) and unused since then. i will take a closer look at the engine and report back.
ORIGINAL: doxilia
Request:
Can you take a picture of how the nose gear steering is setup?
David.
Request:
David.
david, here are the requested photos: the nose gear is tightly fit into a fiberglass box and wedged with a piece of wood and screws. the box is bolted to the firewall. and by the looks of the chin the nose gear has failed before.
it looks like the spring air wing retracts would retrofit fairly easily, the nose gear is another story. and last photo shows a label that says 'aero composites 1978'.
