Scepter by Rusty Van Baren
Hi all if anyone has any info on the plane Scepter would be appreciated even better if anyone has one for sale, please let me know.
Thanks Pat Lasercut USA |
Pat,
the Scepter and/or Super Scepter are variations on the Deception if memory serves. There are at least a couple of threads here on the subject. It's basically a RE configuration Deception with a pipe tunnel spanning the length of the fuse. It has a more "slight" curvature to the pipe tunnel top deck than the original Deception canopy which is short. The tunnel also spans the width of the fuse which is flat at the base of the tunnel. It wouldn't be hard to modify a Deception plan to result in a Super Scepter. The model was molded and glass fusees were made which consisted of 2 pieces - the fuse and the pipe deck. As far as I know, the wing, stab and vertical were all Deception. Actually, the top is not unlike how the Arrow is done exccept it doesn't have the inflexion in the canopy that the Arrow has. It's top is also shallower than the Arrow's. Other than producing the glass pipe deck for a complete kit, a laser cut Scepter would be cool. Then again, A Deception kit exists already and one can use the standard canopy or use a larger Escape canopy for a very similar model. David |
Hi David, Thanks for the info would you know where I could get some pictures of either the Scepter or Super Scepter or if it is possible to contact Rusty Van Baren to get some insight of his design??
Pat |
Hi All, Does anybody have a Scepter or Super Scepter that I can get some dimensions from I understand that it is almost a copy of the Deception the wing and stab are pretty much the same I am looking for some fuse dimensions.
http://www.rcuniverse.com/forum/clas...ml#post9461685
Link above probably doesn't help much, but linking the two posts together might refresh sombody's memory? |
| All times are GMT -8. The time now is 11:13 AM. |
