RCU Forums
-   Classic RC Pattern Flying (https://www.rcuniverse.com/forum/classic-rc-pattern-flying-379/)
-   -   Supertigre X60 (https://www.rcuniverse.com/forum/classic-rc-pattern-flying-379/11612030-supertigre-x60.html)
iflyjr 01-14-2015 07:20 PM
Supertigre X60
I need a header for a side exhaust x60. Anyone have one for sale or does someone make one?
Thanks Tim
Pylonracr 01-14-2015 08:41 PM
Call Macs products. If he doesn't have one he will make one for you. He made me a custom angled header for a rear exhaust Jett 50, I had it in 2 days.
doxilia 01-14-2015 09:23 PM
Sheldon's Hobbies has a Macs long 2911. Long is usually used for a side mounted engine.
Check the auction site - $22 plus shipping. :)
What model is the engine going into?
David
dhal22 01-15-2015 03:47 AM
David
David, don't get banned.
doxilia 01-15-2015 04:46 AM
Oops! Thanks for the reminder.
Just trying to help a guy out.
David
Pylonracr 01-15-2015 07:51 AM
Did I post something wrong too?
Apparently I am not well versed on all the rules here
iflyjr 01-15-2015 10:25 AM
Thanks Guys
Plane is an UFO with fiberglass fuse.
Tim
doxilia 01-19-2015 09:20 AM
Tim,
For an upright install you'll need a standard header, for a side mount you'll need a long one so the pipe clears the wing.
David
Jim Johns 01-19-2015 04:59 PM
1 Attachment(s)
Some may disagree, but take it from a man who tried to fly a glass Dirty Birdy with a side exhaust X60 - you WILL want more power unless your UFO is MUCH LIGHTER than my DB was. A Super Tigre S-61 or Como 61 will drop right into the same mount as the X60 and make a LOT more power. Photo shows good friend Steve G. posing with my DB after the S-61 was installed.
Another reason I mention this is that the X60 requires an adapter plate and a header to fit which is not interchangable with any other ST 61. The S-61/Como 61 use a simple bolt-thru header. YMMV.
Originally Posted by iflyjr (Post 11962113)
Thanks Guys
Tim
http://www.rcuniverse.com/forum/atta...mentid=2065511
iflyjr 01-19-2015 05:51 PM
1 Attachment(s)
Here's my Dirty Bird from 1981.
iflyjr 01-22-2015 07:13 PM
2 Attachment(s)
Here is what I put the Supertigre X60 in. I order the header from Sheldon Hobbies today. Brings back old memories.
Tim
doxilia 01-23-2015 09:54 AM
Tim,
fitting combination! UFO's are simply kewl!
David
