RCU Forums
-   Classic RC Pattern Flying (https://www.rcuniverse.com/forum/classic-rc-pattern-flying-379/)
-   -   MK "Magic" Plans... (https://www.rcuniverse.com/forum/classic-rc-pattern-flying-379/463463-mk-magic-plans.html)
Steve25 10-16-2006 07:20 PM
RE: MK "Magic" Plans...
Hey Dave,
If I can get my hands on that magazine, I'll make ya a copy.
I didn't buy the Magic kit yet, instead i baught a Curare 60 after having a weird heavy crash with my Curare .40. Still can't explain why it happened ???? :(
Anyway, the fuselange is back reinforced and glued. But still a heck of work on the wing.
Due to a coming move, most equipment is packed, so no building and repair yet. Once everything at the new place is in order, the glueing can continue, putting the .60 in order, and prolly buying the Magic as well, while the .20 .60 Curare will get retracts and flaps, as well as the magic
Hey Dave, can you send me some pics and movies once it flies ? And a comment how it flies ?
You will prolly notice that it kinda drifts through manoeuvres. In any case, that's how a Curare does :) . And I simply LOVE it
greetz,
Steven
Dave Smith 10-16-2006 07:52 PM
I built a Hobby Barn Magic. A beautiful airplane to look at,but applying rudder was about the same as applying lots of down elevator! Tragic.
Steve25 10-16-2006 08:23 PM
Hello Dave,
That sounds weird to me, as the wing and fuselange is actually, except the motor cowl, and how the engine is mounted the same, while the Curare is a dreamplane, that normally reacts like a dream
Although, before my last crash, I totally had no problems, making rolls, snappy rolls, and after taking it up into a small looping, it broke out, turning around it's axis, in fact all, could get it level, but noticed that then, when I used the elevatot, it tended to roll right, what ended up that i could not perform my last curve, didn't even could get my nose up, while giving complete roll left, combined with elevator up, it still ended up in roll right ???? Now, my RC system can not make any mixes ??????
Heck, even after the crash, every command was still in normal working condition.
If I now hear your story, I ask myself if this is not due to some error as well ?
Remember, I have seen a Magic performing very well at the end of the 70's, beginning '80's
greetz,
Steven
dave.windymiller 10-17-2006 07:07 AM
Hi Steven
If the magic flies half as well as my curare does I'll be happy. The Curare took a lot of careful trimming with tip weight to get bunts and loops on track but once done it flies as straight as a die. The other major tweek that helped was to increase wing incidence to make dives stay straight down (it used to pull up towards the canopy). Ive noticed around 50% of the trim charts that are available on the net suggest doing the opposite.
Actually my magic uses my original balsa curare wing (I built a foam one for the curare after i smashed it but Ive since repaired the original wing). Its slightly different to the magic being narrower at the root but what the heck. I am going to modify the tips to match the magic as its got an angled underside for some reason.
Dave
Steve25 10-17-2006 07:51 AM
Hey Dave,
Keep me posted, as somethings thrives me to the 'must have' feeling. I keep having warm feelings towards the whole Curare range, have them now ;) , the Magic, another patternship that looks kinda equal to the Magic, a big pylon ( speed Cobra ) and.... a Graupner Piper Cherokee they used to have a .61 version.... anyway, I'll be having them sooner or later ;).
But would be great to get the magic fly on rails as well, don't you think ?
For all the Curare lovers. I can get my hands on new Curare .20 and Curare .60 kits.
The .20 has foam wings, and fiber fuselange, and I'm waiting on the .60 kit to see how that will be build.
I also have the original Mk. Curare .40 (or Minare some say ) plans...
succes with the Magic,
Steven
Stuart Chale 10-17-2006 05:59 PM
My first pattern plane. A hobby barn Magic. I remember waiting months for it to arrive, with numerous calls that it would be sent out this week :)
Mine had a different lower engine cowl than the one pictured. More of a complete mold around the lower front of the plane as I remember. The wing sheeting was nice as well. Full 12 inch wide sheets of balsa. Three pieces lap jointed and glued to make a 12 inch wide piece.
Mine was a beauty all hand rubbed laquer but weighed a ton. Still it flew well at speed. Pretty nice in the rolling maneuvers. The odd behavior with rudder was with extreme rudder throws on mine. Knife edge was fine unless you added too much. Then it did some weird stuff.
Stuart
baldrick 10-20-2006 12:13 AM
1 Attachment(s)
I was posting in a curare thread but just found this one. I was given this aircraft complete. Is is a "magic"? I' am unsure due to the tail plane and wing tips.
Bootalini 10-20-2006 07:25 AM
Fuselage is a Magic for sure. Wing/stab on the Magic was double taper if I recall which does not seem to be the case here although the angle of the photo is not the best to determine. Could be a Saphir wing but most likely some other wing/stab with the tips chopped to look like the Saphir. I remember reading that those angled tips were designed to help with snaps but did not really work. Anyone else?
Jeff L
baldrick 10-20-2006 03:34 PM
1 Attachment(s)
Here is a shot of the wing if it will help. Some new light on this one. The kit was purchased from Airsail NZ in the 80's. It is not the original wing but was built to the plans minus flaps. The kit was also referred to a "Magic" and/or Flyingfish.
baldrick 10-22-2006 11:55 PM
Does anyone know the pattern sequence which the Magic was "designed" for?
pimmnz 10-23-2006 03:07 AM
Looks like a Magic fuselage but definately not Magic wings. Someone said `Saphir' wing, and it probably is. Magic wing was quite different to Curare ditto. I have a small plan somewhere...
Evan.
Steve25 10-23-2006 08:14 AM
Hello Baldrick,
The Magic was a further development of the Curare, and was flown by Hanno Prettner, the designer to do the same a the Curare, which was a RC1 patternflyer. The Magic was devellopped in order to get better aerodynamics.
I have seen the Curare 40, Curare 60, the Magic, as well as an Arrow (from W. Matt Austria ), as well as some American models, like the Dirty birdy.
But the Curares, Magic and Arrow ruled ( could be the pilotting as well ofcourse )
greetz,
Steven
PS : One of my friends makes kits from the Curare 20 and Curare 40 , so, if interested, msg me
JPal101 10-23-2006 10:44 AM
While I find this interesting I would like to no longer receive e-mails about this subject and I just cant figure it out. Please help
Stuart Chale 10-23-2006 02:11 PM
1 Attachment(s)
I found a picture of my Magic dated May 1983.
Stuart
Steve25 10-23-2006 02:48 PM
Such a nice pic !!
Wish it was mine, maybe soon , but I would take all the original colors.
I'm still impressed with a lot of airplanes from Hanno.
roncoleman 10-23-2006 04:01 PM
sc204,
Nice looking Magic.
Ron
baldrick 10-23-2006 04:49 PM
Thanks for that guys you have been alot of help. I assumed that it wasn't a true magic and SC204's pic confirmed this. I think it was a "ripped off" copy with the differences that I can see. The wings and stab came as foam cores originally with the shape my photo's show. Also I think I can see a difference where the airflow exits the fuse after the pipe and the cowl has flared vents at the bottom.
Cheers
guys and happy landings!!
Stuart Chale 10-23-2006 06:38 PM
Mine was the Hobby Barn glass version of the magic. Other versions probably had subtle differences. My first pattern plane. Colors and pattern was taken from a magazine picture of one of Prettner's Magics. I used the pattern and colors for many years on different planes. My planes were identified as earth colors as opposed to the red white and blue of most pattern planes of the time.
The plane was all painted hand rubbed laquer. I had no clue as to the meaning of weight for my first pattern plane and it was a lead sled. It did have an adjustable stab though, and initially had wheel well doors that never worked well. Flew well at speed but stalled if too slow. I eventually sold it a the WRAM show.
Stuart
roncoleman 10-23-2006 06:47 PM
1 Attachment(s)
baldrick,
Here's a photo of a Saphir and it's wing design.
flywilly 10-24-2006 03:40 PM
Hey Stuart,
Do you remember Willie Macek and his pair of YS .60FR powered Hobby Barn Magics? His were up around 10lbs; so not exactly lightweights!! Willie flew them very well and was always tough to beat, but he was such a nice guy you never felt too bad. Unfortunately, when 'turnaround' pattern arrived Willie (as well as many other top pilots in the northeast) 'retired'.
-Will
baldrick 10-24-2006 05:01 PM
Thanks for the pic RONCOLEMAN. I've always wanted a "magic" as I like its lines. I'll contact the seller to see if they know what exactly it was. I do recall there was a modified magic but haven't a clue as to what it looks like. I'll try to make my "Deception" and "Dirty Birdi" as original looking as possible seeing as I don't have the plans for them.
Steve25 10-24-2006 06:43 PM
Hey Baldrick,
You can find a Dirty Birdy here : http://www.bridiairplanes.com/hangar/dirtybirdy60.html.
As I normally can buy an MK Magic still kitted, I could the plans be copied, but it will cost a fair amount, as I noticed when I let the plans of Nelson's SU27 print on the exact measurements.
As the plans of the Magic will be slightly bigger, they will then cost probably more, and then they still need to be scanned.
Would any of you be interested in the original MK Magic plans ?
If indeed I get my hands on the kit, there is a chance that one of my friends, of both of us will be start kitting this nice airplane, beside the Curare.
Send me a pm if interested,
Greetz,
Steven
Stuart Chale 10-24-2006 06:57 PM
Willie was certainly one of the better Master's pilots in our area at that time. If I remember corectly he changed the wing sweep on his Magic's. They were heavy and built like a tank. I remeber him cartwheeling a landing and flying the next round like nothing happened :).
I also remember going out to Beefsteak Charlies after a contest with Willie and his family as well as a bunch of post contest fliers. Very memorable. It was the first time one of his kids had shrimp to eat (shrimp and salad bar). I believe his comments were "these are good but very crunchy"
Stuart
roncoleman 10-24-2006 07:04 PM
baldrick,
You could try these two for plans also. I'm sure they will ship to New Zealand.
DIRTY BIRDY plan
http://www.rcmmagazine.com/store/sto...qZKceAtQo72938
DECIPTION Plan
http://www.rcstore.com/rs/general/li...d=41&catego=PL
Ron
baldrick 10-25-2006 02:27 AM
You guys are fantastic!!! The plane is a ripoff copy of the Magic. It was sold as a "flyingfish". I think I'll track down some plans at a later stage and build a "proper" one. I will get the plans for the Deception (I only need canopy, elevator and rudder sizes and shape). Does anyone want a Dirty Birdi Fiberglass fuse? Just pay for shipping and it's yours.
Cheers
