RCU Forums
-   Classic RC Pattern Flying (https://www.rcuniverse.com/forum/classic-rc-pattern-flying-379/)
-   -   Name that plane LOL (https://www.rcuniverse.com/forum/classic-rc-pattern-flying-379/4687204-name-plane-lol.html)
Paternguy 08-29-2006 09:18 PM
Name that plane LOL
1 Attachment(s)
I have decided to design my own pattern ship. I am a big fan of the classic 60 size birds, so I have decided to follow the retro route.
I have decided to use features from a lot of my all time favorites and incorporate them into one design.
Can anyone name the plane I started with. I will let you guess for a while before I lay out where the ideas came from and what my intent is.
wildchild45177 08-29-2006 09:24 PM
RE: Name that plane LOL
a Patriot?
rainedave 08-29-2006 09:26 PM
If you leave off the additional belly section it reminds me of a Mach 1.
Paternguy 08-29-2006 09:26 PM
No think 70's desings. It was one of the big names.
David Cutler 08-29-2006 09:26 PM
A Tiger Moth?
rainedave 08-29-2006 10:40 PM
1 Attachment(s)
No?
turbo.gst 08-29-2006 10:43 PM
I can see the resemblence to a Mach 1..
turbo
rainedave 08-29-2006 11:01 PM
1 Attachment(s)
Maybe...
Paternguy 08-30-2006 04:39 AM
Yes I started with the Mach 1. I always loved the way it flew.
1. I gave it more side area because I wanted better knife edge flight. That's also why I enlarged the rudder.
2. The Mach 1 always seemed to have some roll coupling. So I moved the rudder hinge line to a true vertical position.
3. I have had 2 Mach 1's over the years. One I built and one I bought already built. The one I built always seemed to run out of elevator at low speeds. So I have decided to give it an anhedral stab. Well I also think an anhedral stab will look cool too. LOL. Think Curare and UFO.
4. I also always liked that clean look of a pipe hidden in a belly pan. Like the old illusion.
5. I am planning on using one of my super tiger 90 engines and was concerned about the fuel tank area, so I elected to convert it to a tail draggers for simplicity and extra room in the nose. I also wanted to get 8178 fired up. LOL
6. I also wanted something quicker to build than the Mach 1 fuse. So I changed the way the fuse is built. I just don't feel like all of that carving of the top blocks. I built a Bridi Killer Chaos over the winter and loved the use of Triangular stock in the fuse top, I certainly made it easier to round off the corners. LOL.
Overall it should be a great flying bird. I haven't changed the wing and stab, or there locations.
And I think it will look pretty cool, when its done.
I hope you guy will agree.
Deadstik 08-30-2006 06:17 AM
Paternguy,
Looks to me like you have an EU1 A with Mach One wings !!!! Doesn't really matter as I think you have captured the "spirit" of the designs of that era where they need to fly ballistically and look great while doing it !!! Good luck w/your project...
Dan
Carolina Custom Aircraft
Paternguy 08-30-2006 06:27 PM
1 Attachment(s)
I have a little more work done on my new bird and I picked out a good name ( I think LOL).
I need to make notations on the plans and I will be done.
Paternguy 08-31-2006 05:23 AM
Dan,
I actually think it ended up looking more like the LA 1 than the Eu-1.
Either way I think it looks cool and should fly great. Its not the picture I had in my head when I started, but I really like where my imagination took me.
With the Mach 1 dimensions and the wing and stab it should be fast but yet very stable.
I will post a build thread when I get started on it.
jquid 08-31-2006 12:18 PM
1 Attachment(s)
The Nautilus? LOL!
rainedave 08-31-2006 12:25 PM
That photo is a cross between Andy Warhol, Jasper johns and Robert Rauschenberg. Nice image.
NM2K 08-31-2006 12:30 PM
ORIGINAL: Paternguy
It is beautiful and it does capture the essence of the Seventies. The Mach 1 was my guess too.
rainedave 08-31-2006 09:44 PM
It's looking really nice Paternguy. I'm looking forward to the build!
Paternguy 08-31-2006 11:03 PM
Thanks guys. I will probably order the wood and the cores for it next week.
Did you get your plans yet Dave ?
Paternguy 08-31-2006 11:11 PM
1 Attachment(s)
These are the finalized version of the plans. Let me know if you see anything that I might have overlooked.
rainedave 08-31-2006 11:20 PM
Yes, I got the plans, they are excellent.
So are you ordering the Dynamic Balsa cores?
Paternguy 09-01-2006 04:26 PM
Yes, I will order next week sometime. I need to figure out what wood I have and what I need to order.
Fxrs_tim 09-03-2006 10:24 PM
You could call this one the "Machorare". :) Nice looking plans!
Tim
Paternguy 09-03-2006 11:16 PM
Looks like I might be building two of them. I shared my idea with a Friend from my club and he is really into it.
Paternguy 09-03-2006 11:23 PM
Foam Cores from Dynamic Balsa $42.98
Wood from Lone Star $44.50
$87.48 per airframe. Not too bad.
8178 09-04-2006 07:45 AM
Were there two different wing platforms for the Mach I? Note the wing shape on these Mach Is http://www.rcuniverse.com/forum/m_4704479/tm.htm I always thought it had a leading edge that was a straight line.
Paternguy 09-04-2006 08:45 AM
1 Attachment(s)
My Midwest Mach 1's had a very slight taper to the leading edge. The plans I have also show the very slight taper. I understand that there was a fiberglass version, that may have been slightly different. You might want to check with Dan.
