RCU Forums
-   Classic RC Pattern Flying (https://www.rcuniverse.com/forum/classic-rc-pattern-flying-379/)
-   -   WEBRA 61 MUFFLER? WHERE TO GET ONE (https://www.rcuniverse.com/forum/classic-rc-pattern-flying-379/4780254-webra-61-muffler-where-get-one.html)
airbusdrvr 09-22-2006 03:55 PM
I'm looking at a couple of Webra 61 side exhaust engines but none have a muffler. Is ther a source for the muffler for these engines?
8178 09-22-2006 04:03 PM
RE: WEBRA 61 MUFFLER? WHERE TO GET ONE
1 Attachment(s)
ORIGINAL: airbusdrvr
If it is this Webra the K&B 61 muffler fits. http://www.mecoa.com/kb/61/61-parts.htm part number 30-6102.
Lou Melancon 09-22-2006 07:11 PM
I had to do a similar search for a muffler for an HP .61 that was not originally equipped with muffler. Tower Hobbies sells the Bisson "Quiet" Muffler which is a strap on and works well.
turbo.gst 09-22-2006 08:58 PM
airbusdrvr,
If it is the Speed #1024, some were drilled and tapped. They utilized the same hole spacing as the OS #744, Rossi 60, and Fox Eagle 3. I believe there is an Enya that shares that hole spacing as well. Others needed a Strap- on like the BCM Lou mentioned-- that one works fantastic. I have some of each version of the Speed .61
8178 is correct about the K&B muffler working on the Blackhead / Silverline .61's( 10cc). They also share common spacing with the HB 40-.61, ST 45-60BB, as well as the K&B .61 and .65 Sportster.
turbo
NM2K 09-23-2006 08:32 AM
ORIGINAL: turbo.gst
airbusdrvr,
turbo
The K&B .61 muffler is also identical to the muffler used on the HB .40 thru .61 line of engines and bolts right up perfectly.
rambler53 10-06-2006 10:03 PM
I've got a new in box Webra Speed .61 muffler with all the mounting hardware, but it's about as heavy as the engine. Most run these with pipes. If you want the muffler, let me know, I'll list it here.
