Name the Plane
1 Attachment(s)
Another "Based On" design.
RE: Name the Plane
Looks like a "Compensator" or "A6 Intruder" copy. Dave.
RE: Name the Plane
Sweetater??? Very cool looking whatever it is!!
RE: Name the Plane
Revenger?
RE: Name the Plane
Wow! This is a really nice looking plane.
I cheated by looking up the designer, so I won't put the name to it. |
RE: Name the Plane
I finally got a tattoo. It reads, "Born too loose."
--------------- Ever see the movie where the biker girl is reading aloud the tattoos on the biker boy friend's back and says, "South Kadota"? I laughed until I cried. Can't remember the name of the movie, though. Back on topic. That is a beautiful model. The tail assembly reminds me of the Deception by Jim Kimbro. Ed Cregger |
RE: Name the Plane
Revenger was in RCM and used a canopy more like the Dirty Birdy.
ORIGINAL: stiletto660 Revenger? |
RE: Name the Plane
ORIGINAL: grotto2 Wow! This is a really nice looking plane. I cheated by looking up the designer, so I won't put the name to it. |
RE: Name the Plane
It looks sorta like a Mach 1 take-off. Especially the rudder
RE: Name the Plane
Configurator III?
RE: Name the Plane
ORIGINAL: Jim_Purcha Configurator III? |
RE: Name the Plane
Is that a fiberglass turtle deck on top the fuse?
DM |
RE: Name the Plane
RE: Name the Plane
1 Attachment(s)
ORIGINAL: vintageflyer Is that a fiberglass turtle deck on top the fuse? DM Thanks for the link, grotto2. |
RE: Name the Plane
Found it there too. I'll split it with you.
RE: Name the Plane
New to RCU and got here via Google trying to find info on CG location on a Compensator I just pulled out and dusted off many years of dust. It is in great shape and I have pulled out old pro-line servos etc and putting in new servos, 2.4 etc but I did not mark CG back when I built it and have no info or plans. I now keep all that but wasn't that smart back then. I could figure it or get close but sure would like to know what the good starting place is if anyone knows ? I want to fly it in vintage pattern so don't want to ding it up with way off CG. thanks
RE: Name the Plane
A safe starting point is 25% of the average wing area.
RE: Name the Plane
Hi mGang, Remember George's blown-up sized Configurator with the Webra geardrive back in the early '80s? It was called the Big One. We published it in Flying Models. Dean Pappas |
RE: Name the Plane
ORIGINAL: WEDJ A safe starting point is 25% of the average wing area. Mark |
RE: Name the Plane
1 Attachment(s)
Here's a detail of the plans. It's about 4 3/8" back at the fuselage side.
David |
RE: Name the Plane
ORIGINAL: mmattockx ORIGINAL: WEDJ A safe starting point is 25% of the average wing area. Mark |
RE: Name the Plane
ORIGINAL: Dean Pappas Hi mGang, Remember George's blown-up sized Configurator with the Webra geardrive back in the early '80s? It was called the Big One. We published it in Flying Models. Dean Pappas I seem to recall he flew that with the geared webra, one of the OS gear drive .61 engines, and later with the 4-c 120. Didn't George who also had that tiny version he carried around in a briefcase ? |
RE: Name the Plane
Compensator CG - Thanks for the info - I am off to shop to balance new gear going in now that I have a good target to start from. I am going to go to a separate servo for nose retract instead of the old 3 armed servo in wing and fishing that nose rod up front with clevis to hook up, looks like a Hitec 125 flat glider aileron servo will work well.
| All times are GMT -8. The time now is 09:39 PM. |
