RCU Forums
-   Classic RC Pattern Flying (https://www.rcuniverse.com/forum/classic-rc-pattern-flying-379/)
-   -   Paint for Pattern Planes (https://www.rcuniverse.com/forum/classic-rc-pattern-flying-379/7111882-paint-pattern-planes.html)
RCDENT 02-21-2008 07:06 AM
I'm getting ready to paint my Tipo 750 (glass fuse and 3/4 oz glassed flying surfaces). I'm not a huge Monokote fan. Haven't painted one of these birds in over a decade though. Just wondered what paint systems people are using and which are the best nowdays. Anyone have comments on Klass Kote, Radio South, Nelson Hobby, automotive, etc.? I have an automotive detail spray gun. I'm thinking of using old fashion butyrate dope for the minimal weight buildup.
crashlander 02-21-2008 07:41 AM
RE: Paint for Pattern Planes
RC:
I use automotive paint, in particular acrylic enamel. I find them better than butyrate and as good as epoxy paints.Good coverage, light but takes a little long to dry. You would want to make sure to paint in a clean area. For primer I use Lacquer enamel, great cover, sands easily.
I also use Urethane enamel (dries quick) with same primer as above. I find it better than acrylic enamel and it dries faster with a harder surface.
In either case, make sure you use the reducer and the catalyst (hardener) to ensure fuel proof. I use 20% nitro content fuel. No clear coat required. These are "Martin-Senour" paints.
I buy these at NAPA auto store, but lately the Urethane enamel is getting difficult to find. I find these auto paints to be cheaper than PPG Concept paints and the epoxy paints.
Be careful with the colors as some contain lead, read the labels before you buy and have the proper personell protectection equipment when you paint.
Orlando
cllaurit 02-21-2008 07:54 AM
I have always had really good results with plain old RustOleum. Covers very good, dries quick, dries smooth and resists scratches.
WEDJ 02-21-2008 07:55 AM
I've always used either Automotive lacquer (great color choices) or Epoxy paint. With the lacquer, you need to add a bit of plasticiser
For my Perigee, I have just finished priming with Klass Kote, seems to work just like the old K&B Superpoxy.
flywilly 02-21-2008 08:48 AM
I've used dope, automotive lacquers (with plasticizer), automotive enamels (prefer PPG), Hobbypoxy, Superpoxy and Klasskote. I think Klasskote gives great results, is easy to use (only one reducer), minimally toxic and has good shelf life. I've used a Binks auto touch-up gun for primer and base colors and a Paasche airbrush for trim work. I now own an HVLP gun which I will be trying soon.
My first choice would be Klasskote. If you have a desire to use more colors then probably acrylic enamel (PPG). If I were going to do a 'show finish' (like for Toledo) then I would probably go with acrylic enamel with a clear coat, but I doubt I'll be doing any more of those - at least until I move - my neighbors don't seem to like the smell of paint (especially acrylic enamel).
Proper ventilation is critical for your health as permanent liver damage can result from inhaling some types of paint vapors (Imron is quite toxic for example).
Nothing beats a nicely executed painted finish. Get a close look at the Japanese pattern ships - immaculate!
-Will B.
knotnuts 02-21-2008 08:54 AM
Where can I find a good source for Klass Kote products?
WEDJ 02-21-2008 10:28 AM
ORIGINAL: knotnuts
It is sold direct over the internet.
www.klasskote.com
knotnuts 02-21-2008 12:42 PM
Thanks, Man!
dhal22 02-21-2008 07:46 PM
the plane on post #38 is how a plane is supposed to look after completion. monocote will never touch that. i need to find out how he did that and what type of paint.
http://www.rcuniverse.com/forum/m_70..._2/key_/tm.htm
david
Deadstik 02-21-2008 10:43 PM
David,
I'm not certain, but I'd bet that is a base coat/clear coat acryllic lacquer finish that has been superbly prepared/painted. The whole key to that type of painting is prep work...... as in 2 days just getting ready to shoot primer.... to get a glass look like that simply takes a lot of time and effort... and as you see.. it's worth it.
Dan
Carolina Custom Aircraft
NM2K 02-22-2008 02:33 AM
Before everyone gets all hyped up into trying for glass-like finishes, jump in the car (during the day time) and take a ride to a local airport. Look at the full size aircraft and their finishes.
I build to fly, but I want a decent looking model. To me, Monokote's level of finish is just fine and is easy to match with just about any type/kind of paint. That's good enough for me.
I don't understand folks that put days and days into finishing a model that is going to acquire hanger rash from day one of flying. I can build more airplanes and experience them. Of course, maybe some folks need to experience getting a glass-like finish. More power to them, but I'm glad it isn't me. <G>
When Imron first came out, it was said that if you can just barely smell the paint, then you are already 200% over exposed. That stuff is no joke. Lost a friend to liver disease that used to shoot Imron unprotected in his airport's hanger. I miss him quite a bit. He flew R/C too.
Ed Cregger
crankpin 02-22-2008 06:15 AM
Time to paint
bacosa 02-22-2008 09:57 AM
There are some of us who are masters with monokote (I am not one of them though!) It can almost compete with a good paint job. But I do remember salavating over some of Steve Helms' planes. If I remember he used to have a Japanese builder who did the work. They were works of art and......light. I think that is the age old dilemna. Can you use the paint to get the finish you want yet keep it light enough to perform. I personally prefer automotive paint with base coat/clear coat method and monocoat over the balsa flying surfaces.
flywilly 02-22-2008 10:48 AM
If you want to check out some Japanese works of art go to the Narlar thread in the pattern forum. There is a link to Nishioka's web site about 10-12 posts down. He (or his company) is probably the premier model airplane builder (of pattern aircraft) in the world. He has supplied models to top fliers world wide. I think you need more than just a fat checkbook to purchase an airplane from him :D.
-Will B.
crashlander 02-22-2008 02:38 PM
You most certainly can. Look at pattern airplanes and Formula Pylon racers. All with imaculate finishes and very light.
Atlanta 60 02-22-2008 03:23 PM
ORIGINAL: flywilly
-Will B.
I wanted to check out that site Will mentioned ( http://www2.cnet.ne.jp/yamatoz/ )
I just thought I'd pass along this link which is translated to English using "Google Translate" ...
http://www.google.com/translate?u=ht...&hl=en&ie=UTF8
dhal22 02-22-2008 03:37 PM
ed, i know you're right about the hanger rash thing, but that type of finish fascinates me. i recently acquired an ultrasport 60 with a monocote finish that has seen better days. i don't like it but it serves a purpose. i can place it/throw in the back seat, head to the field and not worry about dents and dings. i can buy rtf planes all day long like that. however, my personal builds i want a paint finish. i will probably make a crate for transporting a painted airplane.
david
NM2K 02-22-2008 04:12 PM
ORIGINAL: dhal22
david
I get the urge to paint once in a while, but then I lay down and take a nap and the urge is usually gone by the time that I wake up. <G>
Just kidding.
I have the Eureka kit of the Banshee. I saw the original (one of them) flown by the designer, Jim Martin, at Lakehurst NAS in the very early Seventies. I just can't imagine a Banshee (even mine) without that beautiful metallic silver paint on it. It just wouldn't be the same.
Like most old farts, I get discouraged by all of the once loved products being discontinued and replaced with new paint technologies. I'm at the point where the brain is about as full as it can get without exploding. I don't want to learn anything else - ever!
It costs a lot of money to get started in painting with automotive paint. At least it is expensive for someone that is only interested in painting one or two models in the foreseeable future. It would pay me to prep it and then hire someone that already has all of the stuff needed to just shoot it for me. But then, I wouldn't have done it...
Ed Cregger
crankpin 02-22-2008 04:29 PM
Airplane with paint.
dhal22 02-22-2008 04:41 PM
actually the warbird builders are using latex paint and a clear coat and coming out as light as monocote. what is monocote a square ft? 1 oz. or so. i saw a very detailed schedule where the guy tracked every speck of finish put on his warbird just to prove how light it can be. i just want a glossy finish that's all. that's why my current projects are headed for the paintbooth someday. 1/2 or 3/4 oz cloth with a water based polyurethane coating is extremely light (and seamless[X(])
david
dhal22 02-22-2008 04:46 PM
somewhere on the pattern forum there was a link to a build thread in japanese where the guy builds a museum quality pattern plane on a 4' table in a tiny workroom. as best as i could tell the plane was finished in silk and then painted. the craftsmanship on that build and especially the finish is unequaled by anything i've ever seen online. i think those planes sell for $10,000 - 15,000 american dollars over there, so it is probably the guy's means of earning a living.
david
flywilly 02-22-2008 04:52 PM
Actually, He was building an Addiction kit (by Star-Craft) for his personal use. There's a comment by another Japanese modeler that the 'workshop' is typical for most in Japan as is the level of craftsmanship - which is pretty impressive. The builder must have uploaded about 300+ photos of the 'build' - a project in itself :).
-Will
RCDENT 02-23-2008 07:56 AM
In the late 1980's, I remember seeing one of Steve Helms's Auroras up close and inside. The finish was immaculate and the fuse appeared to be made from a molded balsa shell. All of the inside parts were sanded smooth and coated so that the interior of the fuse was just as impressive as the outer finish. At the time, I think he said they cost around $2,300 to 2,800 each. Very professional!
I've been pricing out various paint systems, and now I see why film coverings and ARF's are so popular! I can buy the ARF Intruder for little more than it will cost me to paint the Tipo with some systems! Ed has a good point about planes accumulating hangar rash, etc. Still, we do this hobby/sport for a number of different reasons. Sometimes, the important thing is just to have something that flys, other times, there is a lot of satisfaction in the craftsmanship and individuality that goes into a good painted finish. I love to eat out. Sometimes I feel like fine dinining and wine, sometimes I feel like babecue and beer. Both are great, but different. One thing I don't like about film finishes is that the balsa surface is still soft. I almost feel like the plane gets dented every time I pick it up, unless I'm extremely careful. Also, the edges always start peeling up after a while. The auto enamel and epoxies make beautiful finishes, but seem difficult to touch up when dinged. Old fashion silk/dope was so easy to fix.
I think the bottom line is, results depend on the builder and his/her talent and experience with the materials being used.
Anyone used the Nelson Hobbies system? Sounds good, with water thinning and clean up. www.nelsonhobby.com
dhal22 02-23-2008 08:20 AM
i couldn't agree more. if i put that much effort into a finish it would make sense to make a crate for it. i've seen them before. regardless of hanger rash, even if i get a ding on a painted plane i still dislike monocote.
david
crankpin 02-23-2008 08:26 AM
1 Attachment(s)
MonoKote, soft balsa, finishe's, etc. Right, balsa can be dented easily. I have one mono-koted Intruder, and getting ready to monokote another, (finish before MK picture enclosed). I stripped both. You don't have to, but I use BalsaRite, which smells like and goes on like Dope. It gives the balsa strength, plus seals the wood, prior to MK. I also use the woodpecker for aeration, only on areas I do not glass.
In some cases, go a step further. This present Intruder, I glassed the canopy in, then the whole fusleage 3/4 oz. glass cloth and finishing resin. Did away with the original fin, took rudder off, made new out of 3/8" balsa, cloth and glass that also. I have a smooth glass shell, and will monokote over that. I will include a picture of the re-build of Intruder #1, glassed and MK.
This works for me, and why do all this work just on an ARF ? I will do more work on the glass fuselage and foam wings, but I believe in this system, and want the plane to look nice, as well as fly nice, altho I am not that good a flyer.
Vince
