My DEPS Solution...
1 Attachment(s)
Hey, what do you think of my DEPS solution? THis is an Air Wild Hobbies 90 Degree arm, with (1) leg cut off. Then I used (2) Central Hobbies CF pushrods, and ball links. This will control the split elevators on my GP Illusion.
RE: My DEPS Solution...
Clean and very nice, this one will go in my folder.
Thanks. |
Awesome!! :D
DEPS = dual elevator pushrod system?
ORIGINAL: jquid Hey, what do you think of my DEPS solution? THis is an Air Wild Hobbies 90 Degree arm, with (1) leg cut off. Then I used (2) Central Hobbies CF pushrods, and ball links. This will control the split elevators on my GP Illusion. -------------- Great, as long as the output shaft is double ball bearing supported. Single - it might have problems and the tracking won't be so good. Ed Cregger |
i was going to ask myself. what is deps?
david |
ORIGINAL: WEDJ DEPS = dual elevator pushrod system? Mark |
| All times are GMT -8. The time now is 04:14 AM. |
