Radio vs RX channels?
I am looking at a couple different planes from Aeroworks, Cessna's in particular. They call for a minimum 10 channel radio, but only an 8 channel RX. Why more channels on the radio than the receiver? What am I missing? I think the hot weather has cooked my brain.
http://www.aero-works.net/store/detail.aspx?ID=516
http://www.aero-works.net/store/detail.aspx?ID=396
Each mix uses up a channel. You can easily have four servos on throttle and control surfaces that use up eight channels. Mix two together for elevator halves, that's nine. Dual rudder servoes . . . that's ten.
Dual ailerons and dual elevator halves is six on the receiver just for plugging in.
My Feedback: (108)
Some of the models might need an 8 channel radio and 10 servos. With an 8 channel receiver, you still only can use 8 channels, no matter how big your transmitter is. You can use more servo's than 8 with the use of Y Harness, but no more channels. After looking at the plane in the pics, I cannot see why you would need 8 channels unless you have multiple elevator servo's or dual aileron servo's that need to be programed with individual channels. Good Luck, Dave
Here is the page from Chief Aircraft where it shows the 10 channel requirement. I am using a DX8 and am considering one of these to use my DLE30 on.
http://www.chiefaircraft.com/radio-c...cessna195.html
Now that I look at the Aeroworks site their own requirements show a minimum of a 6 channel radio. It may be that I just need to decide what features I do without. It's only 2 channels.
Must be a typo for the 10 channel radio. If you read the manual the plane requires (2) servos for ailerons, (2) for flaps, (1) for rudder, (1) for elevator, and (1) for throttle There is seven channels consumed and if you run an ignition engine the eighth channel would be for a kill switch and if you wanted auto choke a ninth channel would be needed.
You would mix the (2) aileron servos together and another mix for the (2) flap servos. , You could save a channel by using a "Y" harness for the ailerons and save another channel by using a reversed servo for one of the flaps
Thanks Brian ....the one thing I require on all of my gassers is a remote kill switch. I use the RC-100 X for the remote set up. Looks like what I need now is to decide which plane I will spring for.
