Go Back  RCU Forums > Radios, Batteries, Clubhouse and more > The Clubhouse
Reload this Page >
old timers look here must be 50+ years only
The Clubhouse If it doesn't fit in any other category and is about general RC stuff then post it here at the Clubhouse.
Old 04-09-2015, 11:10 AM
  #1401
FlyerInOKC
FlyerInOKC's Avatar
I think its more of a case he doesn't want to place the minimum order instead of can't get it any more. SIG still offers 16 colors of Supercoat Dope, Flatcoat clear, and clear Nitrate Dope.
Old 04-09-2015, 11:59 AM
  #1402
skylark-flier
skylark-flier's Avatar
Just to add to Mike's note - Brodak also offers 54 of their own butyrate colors, plus the sealer, thinner, nitrates, the whole 9-yards - and in several sizes, each. However, with my own project I wanted to mix SIG & Brodak butyrates - both companies say "DON'T DO THAT". Even though they're butyrate dopes, apparently they are not at all compatible with each other. Also, you won't believe the price of dopes & dope supplies these days. I think gold might just be a better deal. However, y'gottadowhachagottado.
Old 04-09-2015, 12:26 PM
  #1403
FlyerInOKC
FlyerInOKC's Avatar
Its hard to argue with the manufacturer on stuff like that.
Old 04-09-2015, 12:27 PM
  #1404
Redtail_Customs
Galloping . Stunthanger a control line site. Most use dope on there planes I'm putting together. A few ukies. Just for the fun of it
Old 04-09-2015, 01:09 PM
  #1405
GallopingGhostler
GallopingGhostler's Avatar
Originally Posted by Redtail_Customs
Galloping, Stunthanger a control line site. Most use dope on their planes; I'm putting together a few ukies. Just for the fun of it
I'm a member of that site and occasionally post there. Am working on a few ukies too, but been slow going at it. Got one I just revisited and really want to do, a 1960 Berkeley Interceptor. Same proportions as the Sterling S-1 Ringmaster, but has a thicker wing section for better stunting.
Construction though is a bit weird and weak, uses 3/8 inch thick profile fuselage front splice jointed to the 3/8 inch thick balsa profile midway of wing. Wing is built with fuse in an odd manner leaving the trailing edge butted up against the fuse back instead of penetrating or passing through, like the rest of the ukies. I'll need to procure some 3/8 inch balsa sheet and fuselage standard w/o heavier oak front, regular engine beams and 1/16 inch ply veneered nose to wing. That's the only show stopper for now.
Berkeley has an old M.A.N. ad that says one could build in 42 minutes. Given the quality of their kit wood and die cutting, I find that a little hard to believe. But then, their kits were reasonably cheap compared with others, so I guess one got what they paid for.
ID:	2087548   Click image for larger version
ID:	2087549   Click image for larger version
Name:	Berkeley Interceptor35-1.jpg
ID:	2087551   Click image for larger version
Name:	Interceptor Box Contents.jpg
ID:	2087552   Click image for larger version
Name:	Interceptor Fuselage Body.jpg
ID:	2087553   Click image for larger version
Name:	MAN Ad Interceptor4.jpg
Old 04-09-2015, 02:21 PM
  #1406
BrightGarden
BrightGarden's Avatar
Default Sticking with dope and fabric
I'm interested in continuing model building using dope and fabric (several choices to choose from).
To some extent with iron-on coverings you are limited in color - with dope, you can mix a complete spectrum of colors.
While looking around I found a reference to nitrocellulose lacquer that is used for guitars - I believe this is dope.
However, with Sig or Brodak dopes being about the same price, I am not compelled to try it.
Old 04-09-2015, 02:23 PM
  #1407
9thumbs
Sig and Brodak? Thanks, Bing Search didn't find them. I'll check them out right now.
Old 04-09-2015, 02:30 PM
  #1408
9thumbs
Sig doesn't seem to show dope on their website, but Brodak does, at prices I can deal with. Thanks again
Old 04-09-2015, 02:40 PM
  #1409
9thumbs
With silkspan, I could cover the wing,glue it in, then dope the cloth to tighten it. If I use plastic film, what do I use to glue it into the body?
Old 04-09-2015, 02:45 PM
  #1410
GallopingGhostler
They do, it's buried under their menus.
On the Left Side Menu, click Building Materials & Equipment --> Paint --> Dope.
Name:	Screenshot Sig Mfg Dope Web Page.jpg
Old 04-09-2015, 03:07 PM
  #1411
tsolson55
First hobby experance for me was the "Cox PT Trainer", a 0.49 glow plug engine trainer. The wings and engine were held on/in with rubber bands. Moved up to balsa planes from there, and I was hooked.
Old 04-09-2015, 04:04 PM
  #1412
Joe Fisher
Joe Fisher's Avatar
I don't know for sure. I think that the Sig dope might be nitrate with fuel proffer added. It was that Testors was Butyrate , Pactria was nitrate with fuel proffer so they were not compatible.
OK I messed up Sig dose say it is butyrate.
Old 04-09-2015, 04:11 PM
  #1413
Redtail_Customs
You can get dope on the cheap from Aircfraft spruce
Old 04-09-2015, 06:56 PM
  #1414
Joe Fisher
Joe Fisher's Avatar
Yea cheep. I just bought dope to cover my full size J3 almost $3000.oo + $285 freight. In 1980 I covered it and it was less than $1000.oo and Randolph paid the freight. The Funk in my avitar I rebuilt in 2000 https://www.youtube.com/watch?v=StsmTPt5BQw
Old 04-09-2015, 07:12 PM
  #1415
skylark-flier
BG, nitrocellulose lacquer is a true lacquer. If you check the write-up on the website it says to thin with lacquer reducer, a sure sign of a lacquer and not any kind of dope.
Someone else mentioned nitrate dope on the SIG site. Both SIG & Brodak sell nitrate AND butyrate dopes. NEVER, NEVER, NEVER try to put nitrate dope over butyrate - you'll hate yourself for a long long time. Nitrate dope (always clear) is used because of its very high shrink rate - it will tighten silk, silkspan, koverall, whatever like nothing you've ever seen. However, in my experience, more than just one coat will usually have a tendency to tighten so much it becomes fragile and will tear rather easily. The few planes that I've used nitrate dope on got one coat of nitrate, all the rest of the coats are butyrate.
Old 04-09-2015, 07:19 PM
  #1416
BrightGarden
The back of film is color/"glue" - heat sensitive coating.
Lots of instruction on youtube, for instance: https://www.youtube.com/watch?v=F_D2zqXzcfw
You iron it on to the underlying surfaces with one of these:
Old 04-09-2015, 07:46 PM
  #1417
BrightGarden
Joe, watched your vid and really appreciated the total rebuild. Thanks for the share....
Old 04-10-2015, 04:37 AM
  #1418
spaceworm
Originally Posted by skylark-flier
BG, nitrocellulose lacquer is a true lacquer. If you check the write-up on the website it says to thin with lacquer reducer, a sure sign of a lacquer and not any kind of dope...
Please, what is the difference between a dope and a lacquer? Thanks.
Old 04-10-2015, 04:40 AM
  #1419
spaceworm
[QUOTE=HoundDog;12019328]Rich try this
https://www.google.com/search?q=ster...0QsAQ&dpr=1.25
...QUOTE]
Thanks for the link. A good resource for both plans and kits.
Sincerely, Richard
Old 04-10-2015, 04:44 AM
  #1420
FlyerInOKC
FlyerInOKC's Avatar
I found this over at the other site:
It depends on the exact formulation, but most dopes are more flexible designed with use on a flexible material, lacquer usual inst.( this lack of flexibility will not be cured by adding a plasticizers to it, its a smaller size molecule normally in the polymer base making it more brittle)
Here is the link: http://www.rcgroups.com/forums/showthread.php?t=518903
Old 04-10-2015, 04:57 AM
  #1421
donnyman
donnyman's Avatar
Joe Fisher
The video reminded me of my highschool days aviation classes, I had to build from scratch a wing section, my brother had one so I added to his, Loved it!
I believe some of not haveing access to the dopes and such is the results of new EPA requirements the plasticizers used were band, Monokote took a hit, I used some that would not work at all no stretch or bonding that lasted. I think it has improved but I haven't purchased any new stuff since.
It appears we will all have to buckle down and find new ways to continue building and try to get our protective agencies from overreacting they seem to be killng our material manuf. companies.
Inflation isn't helping either. though I must say the lower gas prices have me smiling big time!
The last covering material I used was coverite And I am not sure if it is still sold, I get a lot of what I need from swapmeets so I have a small stockpile of goodies. coverite is a bit heavier than some other coverings but I build in the midsize and larger scale so weight isn't a big concern.
Meanwhile you guys keep up with info I am enjoying your post!
DONNY
Old 04-10-2015, 05:16 AM
  #1422
donnyman
donnyman's Avatar
Truth be told I really don't know! BUT(here it comes) the lacquers I used in the past were too brittle and not fuel proof. dope (the term covers several types) nitrate is dope but won't hold up to fuel, butyrates will. I am not sure what rustoleum is but it is being used more and more I believe with a top coating of some kind of clear coating
back in the day we used to add castor oil to what dope we had as a plasticizer. .......I'll shut up now it's beyond my knowledge base to go further I'd like to know nore also!
Old 04-10-2015, 05:36 AM
  #1423
FlyerInOKC
FlyerInOKC's Avatar
Originally Posted by donnyman
Joe Fisher
The video reminded me of my high school days aviation classes, I had to build from scratch a wing section, my brother had one so I added to his, Loved it!
DONNY
Did it look anything like this one? This belonged to Paul Vieth my father in-law he graduated Aviation High School in NYC around 1942 and went west to build B-29 cockpits during the war. He wne on to work as a licensed A & P with American Airlines for 37 years. the wing belongs to my niece Christine his first granddaughter, she considers it a piece of art and I agree with her. She wants to drive out to pick it up at some point but for now I get to enjoy it. The wing is preserved with a heavy glossy coating of some sort that has held up well over the years. Paul passed away in 2000 from Bladder cancer.
ID:	2087760   Click image for larger version
ID:	2087761   Click image for larger version
Old 04-10-2015, 07:47 AM
  #1424
trainermaster80
trainermaster80's Avatar
you can use nitrate or buterate dope& thinner from wicks aircraft supply. they are in Ill or other states ck the net you can thin it a lot
& get a lot of bottles just right for silkpan, or silk. use my apply silk with a curved sponge method for easy install of silk or silk span
frankie [email protected]
Old 04-10-2015, 08:34 AM
  #1425
donnyman
donnyman's Avatar
That's it thats what I had to build at Haaren high school in 1955. Your father in law either went to my school (Haaren) or aviation trades school. Now that is a fond memory jerker, never thought I'd see another in my lifetime. I remember it well! we made the metal fittings and the ribs were done in a jig. Thanks thats a Hoot!
