High Quality Power Panel?
My Feedback: (19)
IL
I like having a panel on my box, but I am sick and tired of cheap garbage. My current panel has some nice things, like a charger for the ni-starter and a switch for a fuel pump. Actually, it came with a fuel pump, but that was garbage. I have replaced the pump but still use the switch. I fly alot of glow.
My complaints are 1) the back side of the panel is unprotected. The panel is in a plastic tool box and the 12V wiring is a little exposed. 2) The panel is just cheezy . Fuel has erased all the markings, like ON-OFF switches and the ignitor charger is falling off.
I looked at Tower and Hobbico. They are not what I want. Does anyone make a GOOD quality panel?
-Cheech
-Cheech
My Feedback: (18)
Here is some info from http://www.cermark.com/Merchant2/mer...t_Code=PANEL-L
LCD Power Panel
Quantity in Basket: none
Code: PANEL-L
Price: $59.95
Quantity:
Cermark's Design & Registerd LCD Power Panel Plus, use as regular power panel plus radio battery checker and field charger to charge RX/TX/Glow-Starter.
Out-Put for:
(1).12V Engine Starter
(2).12V or 6V Fuel Pump with Fill/Drain Control Switch
Exclusive New Features:
A LED light shows the 12V Battery Charging Status.
A Liquid Crystal Display (LCD) shows the Glow-Plug Driving Currents.
Built-in TX/RX Battery Tester: LCD display the battery voltage under 300MA capacity load status.
Build-in Glow Starter Charger with Automatic 60 Min. Timer.
Build-in "Top-Up" 300mA Charger for TX/RX Battery with Automatic Timmer.
LCD Power Panel
Code: PANEL-L
Price: $59.95
Quantity:
Out-Put for:
My Feedback: (19)
IL
Thanks Galen. I'm sort of looking at that one, the Cermark, and also at the Sig Power Panel .
I do NOT like the specialized voltmeter socket on the SIG. That would mean one set of leads for charging and another for checking. Or at least an adapter.
I would also like to see the BACK of each of these. Is it covered/uncovered or shielded in some way. Maybe I'm picky.
