Lets see your Biplane!!!
RE: Lets see your Biplane!!!
Hi Airroy: It's an easy build. All balsa/ply, sheeted and glassed structure. Cowl, pants, gear, canopy and a really cool set of wing tips are available.
The model flies like it's on rails. Mine is certainly not overpowered with the OS engine, but it still moves right along.
The challenge in flying the Mong is getting consistent landings. The airplane really wants to nose over during roll out. I've noticed that a lot of the guys that race this design have gone to a conventional fuselage mounted gear. It would be an easy mod, and I think would cure the landing problems.
This is prolly the slowest among posted here, a Kyosho Tiggie. Fabric covered and fly on 13.5x6 eAPC on 12 Gp3300 with Jeti Phasor 45/3. Nice plane at 6.5lbs
Here's mine! It's a 55" span Krier Kraft Acromaster built from RCM plans. Covered in white Solartex and painted with Perfect paints. Powered by an O.S. .61 FX. Flies nice!
ORIGINAL: Joe Ortiz
My Hog Bipe is still in the box[&o], but not for long, you guys are getting me fired up[>:]
Here is my Hog and my friends....we built them together..............
#32
NJ
Here's my Dreamer. See the Pilot as well, so far, no stupid Blond mistakes..........................Flies nice with a Magnum 46XLS and a 11X6 Master Airscrew prop
Don
Don
#34
Great looking bipes you guys (and gals). I am going to attempt my first kit build of a bipe this winter, a CG Bucker Jungman. Would LOVE to see any pictures anyone would post of their's or one's they have seen an got a pic of at a field some where
#37
My GP Christen Eagle II (RC Universe Market Place: 121853)
[ul][*] Great Plains 29% Christen Eagle II[*] Fuji BT-50SA Gas-ignition engine[*] Bolley 20x10 prop[*] (4) Hitec HS-5645 airlon servos[*] (2) Hitec HS-5625 elevator servos[*] Hitec HS-5945 rudder servo[*] Hitec HS-81 choke servo[*] Futaba S9001 coreless throttle servo[*] Futaba R129DP 9-channel RX[*] Powerizer 2200mah NIMH RX battery pack
[/ul]
[/ul]
#39
My Feedback: (9)
LA
What a great thread with some good looking airplanes. Right now the only bipe in the fleet is a scratched built ag-cat. 3 lbs with a 14 oz/sqft wing loading. Just kinda floats around. Good on floats too. After I finish the Gee Bee on the building board, I am going to start a scaled down Hog Bipe for a .30 4-stroke. Should be neat.
Ben
Ben
#40
AB, CANADA
Has anyone built a twin biplane? I'm pretty sure they're rare as real planes... the only one I recall is some kind of WW1 Gotha bomber that had the motors mounted on the struts between the wings. I think it had alot of problems with the motors breaking off the struts and falling to the ground below, with the rest of the plane not far behind.
I just did a search. Click [link=http://www.wwiaviation.com/bombers_german.shtml]here[/link] for it. 3 different bipes made by 3 different german ww1 companies (i was right, one's gotha! hehe) the 3rd one is actually a 4-engine, with... i dont know what its called, 2 engines on the same struts, one pusher and one puller on each side of the plane. neat, eh? that plane would be fun to build.
I hope the link worked...
#42
My Feedback: (17)
PA
I worked on Bevo Howard's Buecher when I got out of the Air Force in 67. It's now hanging in the new Smithsonian in DC. This is a 40 size replica that I won't fly. It's just too cool. Cloth covered, hand done checkerboard and stripes, clearcoated. Metal cowl with bump-outs. Probably built in the 50' or 60's. Swiftflier
#49
My Feedback: (7)
IN
I have a 1/2 Scale Smith Mini Plane Scale Model in the basement in the works. I can send more pic's. My hope is that is will make it up the stairs to get it to the field to fly. It is a Jack Stafford models Short Kit with plans, Pic CD, Fiberglass cowl, and landing gear. Also have a 1/4 Scale Smith that is Jack Stafford coming in kit form.
#50
ORIGINAL: RCKen
What's going on down there in September?
Ken
ORIGINAL: Big_Bird
Thanks a lot Ken. Why don't you come on down to Bomber Field in September and watch it fly?
Ken
Ken
Ken
http://www.bomberfieldusa.com/index01.htm
