A dummy's guide to soldering
I must be an idiot...I am building an RC hovercraft, and am getting to the point where I need to solder the wires however, I haven't done any soldering before, so require some advise - what do you do.
Hoverferry-2006 <- Soldering idiot!!!
FL
RE: A dummy's guide to soldering
i would buy a soldering gun (just a warning, do NOT get the coldheat one, it sucks) and some rosin-core (or better yet silver solder) solder. Get some scrap wire and practice soldering on that till you get a hang of it....
this might help also if you are using deans plugs on it..
http://www.offshoreelectrics.com/info.php
(go to "video on how to solder deans plugs)
I like a 40 watt soldering iron, but a 25 will do the trick. First I strip both wires 1/4 inch or so, dip them in flux paste, tin the ends, then simply apply heat when the two ends touch. Hold it still for a second or too until it re-soldifies, and you are done. Heat shrink or tape the exposed wire.
ORIGINAL: hoverferry-2006
BC, CANADA
1 Post
Hello; That is good soldering advice. I just came in from soldering a rust leak on the fuel tank of my plane hauler *87 VW van), so I have recent experience. I learned a neat trick for this problem; load up a penny with solder on one side and let it cool while you scrape and brush the rusty hole. Put the pennt over the hole, and apply gun until the solder runs out from under the penny. You're done, No need for a torch and all the danger that brings with it.
As a mechanic, I made mostly crimp on butt connections, but I wondered how to make a connection that was tidy and easy to hide with heat shrink tubing. I had to wire new two-pronged connectors onto a new lipo 2100 pack, I tinned the tow stripped wire ends, then just layed them side by side on the gun until I saw the solder melting, let go of the trigger watch it harden and cool. Makes a solid joint. The solder completely hides the individual wires. I should have mentioned that I use a waxy soldering flux, that makes the solder flow and adhere
I have four irons, one is 40 watts, two are 80 watts, and one is 120 watts. I used to do quite a bit of leaded stained glass and copper foiled stained glass, and getting a long, smooth bead without having the lead melt through took practice. I also have a rheostat that I can plug my irons into, it allows me to fine tune the heat for different types of solder. Leaded glass took a 60-40 solder, which melted at a lower temp and was less a risk to melt the lead. For copper foil I used 50-50 or 35-65 which took higher temps to melt, but was harder when solid.
I haven't done a single piece since I started flying. HEY! Maybe I can make a stained glass airplane. Think of the sound it would make crashing into the concrete runway
ORIGINAL: khodges
OH
I always twist the wire together, then heat the wire, touch the solder to the wire and as soon as it flows in remove the heat (iron or gun, I prefer the iron) and a second later remove the solder.
I vote is for liquid electricians tape, followed up by heat shrink tubing.
Also, those things with a small magnifying glass and two clips on adjustable arms make things very easy.
ORIGINAL: jettstarblue
Gilhooley?
Thingamabob?
Doohickey?
I did exactly the same thing. Cheaper and better than store bought.
As to iron or gun, if you're planning on doing battery packs or really short leads, I'd recommend an iron.....
If you are new to soldering the best advice I can give is to have everything clean. Next in order to transfer heat from either a gun tip or an iron - "TIN" the tip with solder. The liquid solder will transfer the heat efficiently. If your "TIN" gets looking dull refresh it with more solder and wipe the excess off. There should always be a slight mound of liquid solder on the irons tip. Practice and you'll soon get the hang of it.
John
John
