How to dope nylon cloth
Silly question time;
What is the best procedure to cover a beech veneered foam core wing with nylon and dope?
Anybody any idea's where I might download this information.
TD
TD
RE: How to dope nylon cloth
I don't have any links for you, but I have done quite a bit of cloth (and tissue) and dope work. My main concern is the foam core. I know it's a beech veneer, but I'd still worry about the solvents working their way through to the foam. You might consider one of the new water based polyurethanes rather than dope. Dope is wonderful stuff though...
-David
-David
Thanks David, seepage was my worry, any ideas on a name for one of the new water based polyurethanes? Bearing in mind I am in the UK
Tony, A quick search turned up a product called "aquathane" from Everlac. I'm sure some other UK member will make a suggestion. You should find several suitable products at the local DIY home center.
Good luck!
-David
Good luck!
-David
