fIBERGLASS, WHAT RESIN AND RELEASE AGENT
SD
hI ALL,
i HAVE A COMBAT MODELS F16N. THE BELLY OF THE PLANE WAS SEVERELY DAMAGED IN A BAD LANDING. I HAVE ALL THE FOAM PIECES TO PUT IT BACK TOGETHER. HERE IS MY QUESTION:
I AM GOING TO GLUE ALL THE PIECES BACK TOGETHER SO THE BELLY IS WHOLE AGAIN. WHAT I WANT TO DO IS CREATE A HARD FIBERGLASS MOLD OF THAT BELLY, (LIKE A BYRON FUSE) THAN CUT OUT THE FOAM AND USE THE FIBERGLASS BELLY. IT IS NOT THE WHOLE BELLY BUT MAINLY AROUND THE GEAR DOOR OPENINGS. WHAT I AM TRYING TO DO IS CREATE A REMOVEABLE PARTIAL BELLY. WHAT FIBERGLASS, RESIN AND RELEASE AGENT SHOULD I USE TO CREATE THAT HARD BYRON LIKE FIBERGLASS .
DAVE
DAVE
