McCoy .35
Sao Paulo is about right, but you might want to attach a fuel line and gently blow into the valve and adjust the Venturi flow, as old as our McCoy 35 red heads are possibly another Venturi was in stalled. Larger hole or two holes. On the Venturi. I fly Fox Stunt 35 and they are all different from plane to plane. AJ
