Pressure tank
I'm trying to figure this tank out . I think the blue line is the pressure line , the white line goes to the needle valve body and then to the engine fuel intake venturi . The tubing on the side , I believe to be the the fill . Once the tank is filled you would put the line on the back on the other brass tube and then that completes the seal .
![Click image for larger version
ID: 2274292](https://www.rcuniverse.com/forum/attachment.php?attachmentid=2274292&thumb=1&d=1716396215)
In this picture , (it's the same tank) I'm assuming the bottom tube is feed to the needle valve and top goes to the pressure barb . How did I do ?
ID: 2274293](https://www.rcuniverse.com/forum/attachment.php?attachmentid=2274293&thumb=1&d=1716396215)
Thanks , Mark .
Thanks , Mark .
markwesti (05-23-2024)
Thanks qazimoto , seems I will have to build the tank , nothing I can find would fit . Also I have built the "torque tube" , that was fun . I gave it a 50# pull test , and it passed .
Mark .
Mark .
