lost
FL
hi im not that in to flyin but i have this plane hanging in my room for 10years it has a gas motor i think dont know if its nitro or gas well it has no remote just two wires out the side of the wing i dont know how to start it its not that big wingspan like 3ft it says fox 15 on the motor metal gas tank can any on give me any info plz? what dos fox 15 meen
Hi,
What you have is a control line model; it is intended to be flown on control lines (Approximately .008 in. or so steel wire) in a circle of about 50 feet diameter. The control lines should be attached to a handle which is moved up/down to control the climb or descent of the model. The flyer (pilot) must stand in the center of the circle and turn as the model flys around the circumference of the circle. Beginning pilots usually get very dizzy!!!!
The Fox .15 is a relatively small, 2 stroke engine of about .15 cubic inch displacement.
I very strongly suggest that you go to your local hobby shop and find some competent help before you try to fly this model. The engine uses a special fuel; and once running can seriously injure hands/fingers/eyes, due to the spinning propeller. The model, when flying, presents a hazard to anyone that wanders into the flight path---if struck by the model, serious injury or death could result.
Also, VERY IMPORTANT, if the control lines come in contact with electrical power lines, the pilot could be ELECTROCUTED!!
Hope this helps,
Hope this helps,
Banned
Control line flying can be interesting. It won't hurt to try it.
A .15 engine, you typically use .012 stranded steel lines, 50 to 55 ft long.
When learning to fly them... you want relatively little control. You want to learn to "dance" in a circle following the airplane as it goes in circles. As you get used to that, you slowly add more control throw to the model. And you start with a SMALL fuel tank at first... 5 laps (about 30 sec) will be enough your first flight. (don't want to crash due to being dizzy.)
Without knowing which model you have... and its condition, hard to say if you should try to fly that one as is... repair it... or try a different aircraft.
ORIGINAL: Pattern Student > What you have is a control line model; it is intended to be flown on control lines (Approximately .008 in. or so steel wire) in a circle of about 50 feet diameter.
The only cars that engines of this type were mounted in were "air cars" with propellers, running in circles on tethers. RC car engines are equipped with heavily finned heads to dissipate the heat. Both air engines and car engines run on fuel that contains alcohol and oil. Various percentages of Nitromethane, a power boosting oxidizer, are added to the fuel to go faster. Some racing RC car engines are capable of fantastic performance on fuels with percentages of Nitro seldom used for anything other than pure speed in CL flying. Perhaps that is why some RC car people have the idea that their engines are "Nitro" engines (there are plane engines that have been used with equally high percentages).
drink man,
You might consider contacting your nearest CL (control line) flying club through the "Academy Of Model Aeronautics" web site. Someone will tell you where they fly. Take your plane to the field and let the flyers look it over. They can evaluate it and see if it will fly (it might have warps, etc). Someone at the field may offer to teach you to fly.
If it turns out you have no interest, you might want to sell it to someone and use the money toward a modern car engine.
Good luck whichever way you go.
George
George
