Kit Recommendation
UT
Hi all,
I was going through my basement and came across a bunch of my grandpa's old RC stuff. I remembered as a kid how I enjoyed sitting there for hours watching him build and how I thought it would be cool to build something with my son's and daughter. One of the boxes has a bunch of control line stuff. 3 line controls, wheels, line, wheel brakes and a J R/C engine (I think those are .36 size. So with the things I have I was thinking of getting a kit for my 14 year old to use the J R/C engine, and getting a smaller trainer for my 7 year old and 9 year old. Can someone recommend some kits (No arf) I want to build with them?
Rob
Rob
Hi there
I am sure you will have fun and "quality time" building with your young uns.
One of the main suppliers of C/L kits and gear, and with a very good reputation is Brodak as here ->
http://www.brodak.com/shop.php?CategoryID=2
You will find lots of information on there
I am in the UK and so recomendations for a .36 size trainer will vary from those recomendations from the USA.
I do note however that the easily available Ukey (sp) is a popular choice on your side of the big pond.
It is easy to build, strong, and can stunt a bit if set up to do so.
iirc it has foam wings ( tho I could be wrong here ! ) and that may not be the traditional construction style you seek.
There are plenty of choices though and someone will be along soon to help you more.
If you want a basic trainer for a 35 how about a Super Fly racer:
http://www.brodak.com/shop_productde...ProductID=2544
There's one on Ebay at the moment.....
Many aerobatic options, try SSHOBBIES
http://www.sshobbies.com/prcoliki.html
or if you want to be a bit different RSM has some options:
http://www.rsmdistribution.com/index-2.htm
Tony
Tony
With the stuff you describe I would guess that your grandpa was going to build a scale or carrier CL plane. It is/was common to connect the throttle and brakes (or tail hook) to the third line.
I am not familiar with that particular engine and I don't know of any "trainers" of that size. If you can find a local club that has a trainer, it would be ideal. Trouble with a trainer is that after you get used to the trainer's "round and round", you usually want to do more...which a trainer is usually not capable of.
Of course after you learn to fly, you could add the third control stuff and have fun with stop and goes.
Good luck.
George
Good luck.
George
