SE5a 1/6 Scale
#127
IN
RE: SE5a 1/6 Scale
Thanks Pete. All I have to build yet are the Lewis gun & rack, and the dummy engine. The rest is painting, rigging, and final assembly. This is certainly the longest project I've ever done.
Steve
Steve
#130
RE: SE5a 1/6 Scale
Not that I have enything against grunts, I were one for 4 years. Got any Sgt Rock comic books laying around? You can get them on the bay sometimes. That SE5 is stunning, I hope you get the finished photos up the minute its done.
#131
IN
RE: SE5a 1/6 Scale
HELP! I got my clear gloss poly from Nelson. I mixed 8 drops of crosslinker in one oz., thinned with water and sprayed the front half of my fuse and about a dozen other parts. Total disaster! The clear drew up like water on glass. The solid parts I can strip and start over. The elevator will have to be completly recovered. What went wrong. I had heard that this was the best clearcoat available, so I must have done something wrong. What a stinking mess. Right now I could toss the whole thing in the dumpster and buy a BARF.
Steve
Steve
#132
VA
RE: SE5a 1/6 Scale
Steve,
That's a bummer. My advice is to call Jerry Nelson. I'm sure he will (and want to) help.
While I've never used his clear coat, I have his colors and have been very pleased using his foam brush application technique. So, rather than offer any suggestions or reasons, I think it best you ask Jerry direct.
Your '5' is sure looking great!!!
Dick
Dick
#134
IN
RE: SE5a 1/6 Scale
Oh, I never quit. Just get a little p_ssed at times. Getting in touch with Jerry is a good idea. I'm sure it's something I did. I've heard nothing but good things about his paints. Maybe he can help.
Steve
Steve
#135
My Feedback: (85)
RE: SE5a 1/6 Scale
ORIGINAL: smcouch77
Steve
Steve
Steve,
Sorry to hear that. I've used the Nelson clear coat in the past with no problem. I did test spray some mockup first. It needs to go on in VERY light coats that build up to the finish you want.
Pete
#136
IN
RE: SE5a 1/6 Scale
Thanks Pete. I'm painting a board with my PC10 to use as a base for testing. I'll let it dry for a few days and then try to unravel the mystery. Maybe I'm just not holding my tongue right
Steve
Steve
#138
VA
RE: SE5a 1/6 Scale
Hi Steve -
Sorry to learn about you painting mess. I have used Jerry's paint before and have found it excellent to work with.
If I recall, his instructions mentions about the need to fill the weave of the covering when it's applied over open framework. Whether this may be the cause in your case, I can't say. But, before spending too much time trying different fixes, etc, it would be my suggestion you call Jerry and talk over the situation with him. I know he would be very interested and should be the one who could best solve the problem and get you on the right track.
When in doubt go to the source, I always say
Dick
Dick
#139
IN
RE: SE5a 1/6 Scale
Hi Dick. I talked to Jerry, and he hasn't heard of this problem before. After some experimentation, I think I've figured it out. When he says thin coats, he means thin coats. If I brush it on almost dry, it works. If I put it on with enough to flow, it draws up. Now all I have to do is figure out how to get a gloss finish while dry brushing
Steve
Steve
#140
VA
RE: SE5a 1/6 Scale
Hi Steve -
Sounds like you the problem identified. Yes, if there is one thing I learned from reading his instructions, was that very light coats were key - but only after filling the weave! After brushing on a couple of heavy coats, etc I should think you'd have good base on which to spray. Do keep us posted, though.
One thing I have always tried to keep in mind, is that if something sounds too easy... it's not
Dick
Dick
#141
IN
RE: SE5a 1/6 Scale
Well, I'm back from vacation, and back to work. Actually, I took my wing panels and stitching/tapeing tools with me. Hey! It's my vacation and I should get to do something I like doing too! So, anyway, I've finished all the stitching and tapeing. Now it's going to be a bunch of painting, painting, painting.I'll post some pics when I get the wings done.
Steve
Steve
#142
IN
RE: SE5a 1/6 Scale
My stitching took about an hour per wing panel, and about 1 1/2 hours to apply the tape. Ten hours in all. Actually it was quite relaxing. Maybe I'll take up needle point It's hard to take a picture at this stage that shows the effect, but the slight irregularities look good to me.
Steve
Steve
#143
IN
RE: SE5a 1/6 Scale
Steve
Steve
#144
IN
RE: SE5a 1/6 Scale
I went flying yesterday with my practice plane. I built a Top Flite 1/6 scale last fall to work out the kinks before I finish this plane. I'm using a RCV .91, and it runs great. The plane cruises along at about 1/2 throttle and sounds good. Jack Sheeks is coaching me. This IS my first scale experience. If my contest plane flys 1/2 as well as the Top Flite, it'll be fantastic. It flys smooth, lands without bouncing, and does consecutive loops. What more could I ask of a scale bird? Last fall I had trouble with it nosing over on landing, but with the new Williams Bros wheels I didn't have any trouble. Now if I can get this model finished by the FAI contest in September, I'll be a happy camper.
Steve
Steve
#146
IN
RE: SE5a 1/6 Scale
Jack said he talked to you. Sorry I missed it this year. I'll be there next year for sure. Will you be at the nats this year? I'm going to fly the Top Flite in fun scale. The FAI plane won't be quite finished, but I'll bring it for "Show & Tell"
Steve
Steve
#147
IN
RE: SE5a 1/6 Scale
I've got the colors on the wings. I haven't put the Nelsons clear on yet. I want to let them dry for about a week while I cover the rest of the fuse.
Steve
Steve
#148
IN
RE: SE5a 1/6 Scale
I finished the radio hatch this morning. It covers the switch, charge jack, and remote glow driver. The latch is just for looks. It's held shut with a small rare earth magnet.
Steve
Steve
#150
IN
RE: SE5a 1/6 Scale
Chuck, I'm looking foward to meeting you. I think it'll be a lot of fun.
I decided to go with the seat belt below. I used this photo for my seat, so I might as well use the same seat belt. That's the last detail I had to do before covering the sides. It's just about there!
Steve
Steve
