Brodak's Flite Streaks
Yes. Both the Brodak Jr. Flite Streak and the Flite Streak are as George designed them. I've seen various copies of George's plans and I have his proof set of the plans for the Brodak Flite Streaks. I've also built both Brodak Flite Streak kits. The Lightening Streak is a knock off (not a criticism).
Sorry I misread your question. I don't think either is real close. I think one is smaller and the other is larger. What engine are you thinking about using?
Replikit (in the UK) do a Peacemaker kit - as does Hallam Models.
Hallam:
69, Bole Hill Lane,
Sheffield,
England.
S10 1 SA
Tel: 01142 665624
Replikit:
http://www.replikit.com/
The replikit is a true Peacemaker - the Hallam Peace"keeper" has a solid l/e.
Tony
Hallam:
69, Bole Hill Lane,
Sheffield,
England.
S10 1 SA
Tel: 01142 665624
Replikit:
Tony
I would go with th big Flite Streak for a PAW 15 or 19. Too much engine for the little one, I think. I think Brodak kits are available in England.
skaliwag,
As others have answered, neither. The Peacemaker is not a scaled up or down version of the Flite streak or Flite Streak Junior.
The Peacemaker has a lower aspect ratio wing and a larger but similar tail. The construction method is similar. George used the thick sheet "V" shaped LE and overall wing construction on many of his planes.
If you really want a Peacemaker build a Peacemaker.
As Jim said, the full size Brodak Flite Streak for a PAW .15 or .19.
The FS Jr. is more sized for a PAW .09. I have had a Webra Mk-1 2.5cc and a Rivers Silver Streak 2.5cc in a Jr. and both were WAY too much weight. All it would do is fly level fast. I could have added more weight to the tail for balance to get it to loop, but I chose to switch to a lighter engine (Max-I .15).
Of course this is only one opinion. Good luck, whatever you choose.
George
George
ORIGINAL: Jim Thomerson
