Go Back  RCU Forums > Radios, Batteries, Clubhouse and more > Control Lines
 Royal 45 Conversion to Stunt >
Control Lines For all you fly-by-wire fanatics!
Old 12-28-2006 | 08:41 PM
Default Royal 45 Conversion to Stunt
Has anyone had any experience in converting a R/C Royal .45 to control line stunt? I have heard that the only modification is a venturi and needle value. If true, what venturi sizes and needle valve combinations work?
Old 12-29-2006 | 07:30 PM
scott17's Avatar
Default RE: Royal 45 Conversion to Stunt
I have one I did years ago after my first attempt at RC flight without adult supervision resulted in a broken exhaust flange on the motor. I just made an insert for a venturi and used a K&B(?) spraybar and needle. It actually runs really strong and has lasted longer than I thought it would!
Old 12-30-2006 | 11:52 AM
Thanks Scott17. Do you remember the dimensions of the venturi?
