Enya 35 Help Wanted
Enya 35 Help Wanted
Hi Folks
I've just got hold of an old Enya 35-V T.V in nice condition, which I'd like to use for a stunt engine.
This would involve removing the R/C throttle and fitting a replacement venturi insert and a standard needle & spraybar (Yes, I know I could just lock the throttle open and use it "as is" but I'd like to get rid of the big lump of carb if possible)
Now, I've Googled everything I can think of to try to find the neccessary parts, without success, does anyone know of a supplier who might have them?
I had an Enya 29 many years ago, and it came with various sized plastic venturi inserts, did the 35 have a plastic venturi like that?
If Enya parts aren't obtainable, does anyone know of another engine who's venturi and needle assembly would fit?
Any help will be much appreciated.
RE: Enya 35 Help Wanted
g'day Wilf,
I understand that Ken Enya has a great parts service.
http://www.enya-engine.com/catalogueE_top.html
I have heard only positive reports of delivery times for engines and parts.
Or alternatively have a venturi made up by someone with a lathe and buy something like a Super Tigre NVA.
Good luck
Greg
Good luck
Greg
[link=http://www.enya-engine.com/store/index.php?main_page=product_info&cPath=3_19&products_id=381]This[/link] will be the one you want, I just measured the venturi in my 35.
Near enough to 3 Euro or 2.3GBP plus postage of course.
Many thanks, folks, I've had a look at the Enya Direct site you suggest, and I believe this will solve the problem, thanks again
