Go Back  RCU Forums > Radios, Batteries, Clubhouse and more > Control Lines
 Hanger 9 Pt-19 .36 Arf 54' wing >
Control Lines For all you fly-by-wire fanatics!
Old 05-13-2009 | 12:34 AM
Default Hanger 9 Pt-19 .36 Arf 54' wing
I was thinking of purchasing the Hanger 9 c/l arf .36 with 54' wing. I have a vintage Mccoy .35 redhead that would look good in the plane. Any advise on if this is enough motor for this plane is greatly appreciated.
Old 05-13-2009 | 05:48 AM
Default RE: Hanger 9 Pt-19 .36 Arf 54' wing
Have you used a McCoy before?
They're decent engines, as long as you treat them with lots of respect. Lots of engines from that era did not do well after one lean run. The McCoys were very sensitive to that. They were not harder to set than other brands at all, just didn't stand a bad run as well. But propped right and with a good needle setting, they did good.
They were made to a price. Heck, they even marketed them for awhile in blister packs. Break in was as demanding as with all engines back then. You did not want to let a lean run happen during the breakin. It sounds pretty scary, but it wasn't really, it was just apt to be unforgiving. So you learned early and stuck with what you learned. We were more apt to verify our needle settings that people today. And more apt to have a filter on the delivery line. And more apt to check it frequently.
It will have enough power. Easily enough.
Old 05-14-2009 | 03:28 PM
If its a good McCoy, it'll be enough. I have one of the older (shiny case non-double thunderbolt) ones and its very strong, starts easy, and does a textbook 4/2/4 break. A delightful engine.
I have another newer double thunderbolt one that was so loose new from the factory that it is almost impossible to start. I'll have to try mixing a 50/50 oil/methanol prime mix for it to see it it helps. The thing only has about 10 minutes on it, but it was so poorly fitted its essentially worn out before being broken in.
