Svensson Pinto plane
Hi
if anyone could help, I have a Svensson Pinto mid winger trainer, andI am trying to find informationwhat engine Ican use on it, anyone can help please?
Joe F
Joe F
The Pinto by Svenson has a 60" wingspan, an AUW of approx 4-4.75 lbs. and the recommended engine is .30-.40. An OS 40 LA would be ideal for this aircraft, light with more than enough power for this aircraft.
My Pinto had strip ailerons and probably yours have too.
ORIGINAL: Red B.
Regards
Joe F
The Pinto was designed quite a long time ago when engines were a lot less powerful than today. However, as long as you refrain from full power dives etcetera I think you will have no problem with the 46AX.
I understand it that you already own a 46 AX. If so go ahead and use it. It will work fine, ut don't do violent maneuvers at full throttle.
Given the choice between the 40LA and 46LA I would choose the 46LA. It has a little extra power compared to the 40LA while still weighing the same. The 46LA is one sweet running engine that has become very popular in C/L stunt.
Hi and thanks, I have both engines the OS 46 LA and AX, so the 46 LAwill work well on it so no need to get the 40 LA
Thanks again mate
Joe F
Thanks again mate
Joe F
