Control Lines For all you fly-by-wire fanatics!
Nobler ARF Advice
Old 10-29-2009 | 12:06 AM
Default Nobler ARF Advice
Hi Gang;
Got a Top Flight Nobler ARF and OS MAX 46LA-S comming, and would like some advice on what to do to improve on the arf parts that should be junked and not used. Already know to change the leadouts, but is 90lb 7 strand .038 plastic covered ss leader wire OK to use. Guys, I'm really not an ARF guy, but am reliving good old times in C/L. Am presently flying a Smoothie ARF, first step back in, and an RSM Ringmaster, what a joy to build and fly. Always wanted a Nobler, soooo what would you change to protect your efforts.
DAVE
AMA 39847
BPA 6X
Old 10-29-2009 | 06:25 AM
Default RE: Nobler ARF Advice
I havent put together one of the Nobler ARFs but if you drop into either stunt hanger or stuka stunt works you will find more advice than any sane person will want to read.
Bob
Old 10-29-2009 | 03:41 PM
stuntflyr's Avatar
Here are some links from Stunt Hangar threads.
http://stunthanger.com/smf/index.php?topic=372
http://stunthanger.com/smf/index.php?topic=8276
http://stunthanger.com/smf/index.php?topic=10588
Chris...
Old 10-29-2009 | 05:47 PM
Thanks Yall.
DAVE
