os .20
Voodoo=.19-.36
Satan =.35-.36
A modern schunerel .20 would do on these, an older .20 would be kinda dull my opinion.
Jr Satan = .15(down sized VooDoo)
Do not remember the Satan ever being kitted.
Hummn
Uploaded part of VooDoo plan and window said it finished-don't know where it went???????
Satan =.35-.36
Hummn
ORIGINAL: jayseas
What is meantby a hot .15. can you give some examples?
Most of the older designs were designed before scnuerle (or even PDP) became available. For that reason a plane listed for a baffle .19-.35 can fly with equivalent power from a schnuerle .15-.25.
If you go back earlier to designs from the forties to very early fifties, the difference becomes even greater.
The plane that I remember for having the largest engine spread is the Señor Puddle Jumper which took .074-.30. The rectangular engine bearers could be mounted horizontal or vertical, with corresponding cut-outs in the firewall.
George
Take a look here. http://f2dnews.homestead.com/Info.html We are talking Cyclons, Foras, etc. etc.
George, I learned to fly CL on a Senior Puddle Jumper with a Cameron 19. I have plans and Cameron 19 and may someday build another.
ORIGINAL: Jim Thomerson
...George, I learned to fly CL on a Senior Puddle Jumper with a Cameron 19. I have plans and Cameron 19 and may someday build another.
jayseas, baffle porting has one port opposite the exhaust to transfer the air and fuel mix to the upper part of the cylinder. As the mixture enters the upper cylinder, it hits the baffle on top of the piston which causes a swirling motion.
Schnuerle porting has transfer ports with booster ports to cause the swirling action because the piston has no baffle.
George
