Control Lines For all you fly-by-wire fanatics!
Control line trainer
Old 08-02-2023 | 07:11 PM
Clean's Avatar
I did this plans tonight kind of in a hurry. Had to baby sit until late. IF there are steps that are unclear please don't hesitate to send me a message. It will help me clear up the plans.
Old 10-11-2023 | 01:23 PM
You can get on your computer and look at sug he gives pretty survey of control line flying. The Ringmaster is a good start.Brodak makes several U control variations. Plus handles lines and all types of support equipment. Props and a lot of basic information types of lines proper lengths. Top flight also makes a few but they are more advanced. Get repaired your going to crash, even the best of the best flyers crash, old saying (you fly you crash). If that concerns you just don’t start. It’s not a simple hobby.there is a lot to it. And if your up to the challenge by all means get a plane. All your support gear, join a local club. That’s sometimes hard to find. And locating a flying site can also be time consuming. I’ve Been chased off several fields, usually a baseball diamond is a good start. And usually fenced in. Spring and summer usually has issues they are playing baseball. But fall and winter they are usually vacant. If you crash please pickup and be sure to get all the parts. But investigate to determine if a malfunction was the cause. That’s how you learn the hobby. I suggest you build your first plane. You can learn a lot about the hobbyAJ.
