Max-s .25 in a flite streak ARF
1 Attachment(s)
Hello all, I have been flying a flite streak ARF on 60ft lines with a FP .25 for power and it flys great, no shortage of power.
I just picked up a very nice max-s .25 baffled piston here on RCU for a song. I have another FS ARF in the box and was thinking of using this engine in it. I am guessing this engine will not be as powerful as the schnurle ported FP I'm currently flying. I have not run the max-s yet, so I'm not sure of its power. I am going to try a APC 9.5X4.5 prop for the first flights. Will I be safe to fly on the 60ft lines like the FP or should I go with 52ft lines first? I'm kind of a C/L rookie and would not like to put this plane into the dirt on its first flight because of a stupid mistake. Anyone have any tips or suggestions for running this engine? Thanks Mike |
RE: Max-s .25 in a flite streak ARF
1 Attachment(s)
Oh boy, those pics came out awful.........
Assuming you are going to use it as-is with the throttle open, it will have a bit less power than the FP. The Max-S was known to be a pretty powerful baffle engine and the Flite Streak was designed to fly with a baffle .19 to .35. That said, give it a try on the 60' lines. If it can't hack it, then decrease the line length.
Make sure the engine is broken in with a few short "heat-cycle" runs if it is new. Since it is iron/steel, you might consider using some castor in the fuel also. BTW, some guys are flying the ARF Flite Streak with a FP .15. George |
Yes, I'm going to pin the throttle wide open on this carb and go for it.
This engine has been run before, but not much from the looks of it. I have a case of fox "Dukes" fuel, 10% nitro and I spiked it to 24% ALL castor. This is what I've been running in my C/L engines. I use Omega for my R/C planes. I would think the .15 FP would be the bare minimum for power. I prefer a little more than that just to be on the safe side, especially being that I am still a rank beginner. Thanks for the advice George. Mike |
I've flown a kit FS (30 years ago) with a Fox .25 from that era on 60' lines. That old Fox was a lot stronger than I ever expected it to be when I bought it.
A baffle piston MAX .25 should fly a flite streak without any problem. The MAX .25 is a good 10 years newer in design than the MAX-S .35, and is darn near as powerful as the MAX-S .35. The MAX-S engines (.30, .35) were introduced in 1963, the MAX .20 and .25 didn't come along until the early '70s.
Back when I was at school, I had a friend who had one on a big flying wing (some old Aeroflyte kit, not sure what it was called). His .25 really hauled with a master airscrew 9x4 on it, I don't reckon it was much down in power compared to my MAX-S .35. I don't think the MAX .25 would do a 4-2 break though - better to run it at a nice fast slightly rich 2 stroke. Incidentally, I am aware of a guy here in Oz who flys a full size flite streak successfully with the the .25s little brother, the MAX .20. I really love those old baffle piston OS MAXes. They are sweet little engines - easy to start & tune. cheers, Colin |
Thanks, I'll have no worries about the performance of this engine then in the FS ARF.
BTW, I also have a few brand new MAX-S engines in .15, .20, .30 and two .35, all R/C. I also have one slightly used .35 C/L I pick them up mostly at epay. The C/L versions are the hardest to find and win by far. |
You and I appear to be suffering from the same addiction :-)
Since getting back into C/L a couple of years ago, I have collected old OS MAX series engines from .10 to .60 inclusive. 1 x .10 FSR-S (one of only two schnuerle ported engines I own, the other is a Norvel) 2 x .15 (one C/L, one converted from R/C) 1 x MAX-III .15 (absolutely beautiful engine!) 1 x .20 (C/L version) 1 x .25 (R/C version, now converted) 2 x MAX-S .30 (one C/L, one NIB R/C, now converted to C/L) 2 x MAX-S .35 (both bought as C/L variants, one was my original 'big' engine bought NIB in 1981, the other 2nd hand from eBay) 1 x MAX .35 "big shaft". Transitional model between MAX-II and MAX-III .35, called a 'combatnik' in the US. 1 x MAX-H .40 (had a hard time getting the venturi for this, now converted and a wonderful engine) 1 x MAX-H .60 (still in R/C configuration - beautiful engine but not sure about using it for C/L) I'm nearly as bad with Enyas as well. My wife has given up hope :-) cheers, Colin |
| All times are GMT -8. The time now is 08:54 AM. |
