e- flite 260
RE: e- flite 260
You posted this in the crash and rebuild forum. You would probably have much more success gathering info in the Electric General Discussion section of these forums. Also for anyone to help, you need to give more info such as batteries you are using, what you would like it to be able to do, etc. The more you give the better we can target our responses.
BC, CANADA
RE: e- flite 260
I run this on an eflite 480 and castle 35 amp and several different 30C 2100 packs. it has all the power and then some, it just does not need anymore, what is wrong with yours? I rip mine hard 3D all day
BC, CANADA
RE: e- flite 260
as mentioned, post your set up and skills, they are important to help you out. the plane is kick ass for the $ if set up.
Its extremely important to have incidence and CG in tight check all times on this one. The Eflight 480 has loads of power for it.
