Go Back  RCU Forums > RC Airplanes > Crash & Rebuild
Seagull 54" Ultamate Biplane Firewall >
Crash & Rebuild Post your crash stories, pictures and if you want to document your rebuild you can do that here too!
Old 06-09-2025 | 04:19 AM
Default Seagull 54" Ultamate Biplane Firewall
I am rebuilding firewall on a 54" Seagull Ultimate Bi-Plane with a 26CC gas engine. Should the Firewall have any right thrust built into it?
Thanks Gary
Old 06-22-2025 | 09:02 PM
I don't know the seagull kit, but yes it should have right thrust. If not you should shim the engine to add a couple degrees of thrust.
