RCUNIVERSE Moderator Crashed Airplane
My Feedback: (8)
CO
Actually, it was 2 weeks ago and I wrecked my wife's new trainer on my first flight of the season. How embarassing that I couldn't even fly a trainer. I made up for it by getting back on the "horse" and flying my super hots, Global .25 AT-6 Texan (this one hurts to fly since it is so unstable and fast), and one of my 1/2a scratch built jobs.
Don't know why the trainer crashed, I lost all controls 1 minute into the flight (battery checked out good, receiver also appears to be good). I first lost ailerons, no problem I began to fly with rudder alone, I then lost my elevator control, and finally rudder. She went in nose first into a plowed field.
Well, she's already rebuilt and believe it or not, I'm actually a little gun shy about testing this puppy out again. I never thought I'd admit to be afraid to fly a trainer, hahahhaha. Wish me luck....
AZ
lol
your wife must have had a good ol laugh
i know why you lost control of it
your reciver is too close to your servos causes interferance and shuts down
same thing happened to me when i was flying my tiger moth
it slamed into the ground so i laughed and went over to pick it up and the wing was broke prop was in 3 pices cowl was cracked
i took it home and put it all back together and have not flown it sence now i am flying my NEW GWS ZERO
GOOD LUCK SO FAR
GOOD LUCK TO YOU
GOOD LUCK SO FAR
GOOD LUCK TO YOU
My Feedback: (16)
Is that true?? How close is too close? On my Magic, the receiver is right in front of the servos. Only about 1/2" away from the throttle servo.
Mike
Mike
AZ
yes its true
your reciver is 1/2 inches from your servo?
does your plane ever glitch?
if so move it about 1 1/2 away clear of everything
the reciver gives out mixed signals when its too close to a servo
like putting to magnets together they push away
are you using a jr or a crapy futaba reciver?
Quote: "are you using a jr or a crapy futaba reciver?"
Hmmm....I'm not biting! Don't want to lower the tone and get into a JR v Futaba handbag war.
If your getting "glitches" for your rec being "too close to servos" something is wrong with that rec.While i do run servo wires to one side and rec anttena to to the other(most of the time). I have never seen a problem out of my equip. and they are on 3/d to trainer planes. Even my b17 rec. is only 2" or less from the servos in thr fuse.
So dont fall for that B.S.
My Feedback: (7)
I AGREE WITH B-17!
I have many planes that the receiver is litterally next to the servos and never a problem!!
I'm sorry you crashed HOMEBREWER, it reminds me of those CARTOONS in the AMA magazine.. What a bummer, going to teach someone and crash. INSULT TO INJURY! I have empathy for you.
HAVE YOUR RADIO GEAR CHECKED OUT..
RON
RON
CRASHES
I feel sorry for anyone that crashes their plane with equipment failure. I had that same thing happen to me. My ailerons stopped than my throttle went to idle. Nothing I could do but watch it go in. Very helpless feeling. I found out, when the plane was put into a loop the receiver would stop functioning. Tested on the bench right side up worked upside down didnt work, probably a bad solder joint or something. Threw that receiver out. Never had the problem again.......KNOCK ON WOOD!!
RBECK
RBECK
My Feedback: (8)
CO
Found problem
I think I found the problem which caused the crash. I was charging my batteries and the charger was acting up intermittently. The charger would show a intermittent short by blinking out and then it would be fine after a few seconds and resume charging. All of a sudden, while covering a wing in my shop, large billow of smoke came pouring out of the trainer. I almost had a fire on my hands, the battery leads were glowing red hot. I replaced the switch harness and battery, all appears fine now.
Oh man, thank God you were there when it happened. Hope all works out for ya now. Hate to hear about you crashing too. Have a great flying weekend to all youse guys.
my trainer carshed my trainer too
Don't feel bad. After 5 planes that were wrecked due to no experience and not having anyone to help me, I finally found this dude that could help me. I was flying an Avistar .40 and he took it on its maiden voyage after checking the WHOLE plane out. At about 10 ft in the air after take-off she hooked left and dumped herself face first on the pavement. I didn't really care since I have wrecked every plane before this. My trainer was baffled. When I took it home (and apart) I noticed the fuel line from the pressure line was ripped and my plane was full of fuel. So it turns out, the fuel was leaking in the fuselage rapidly when I was fueling her up.Then on take off, all the fuel went to the rear and tank slapped until she couldn't handle it and just crashed! I didn't think I would ever learn to fly, well I did!(finally)!!! Oh yeah and off the topic, the reciever being close to the servo's had nothing to do with anything but the wires should be in a neat fashion to prevent interference!
-Good luck with your charger next time!
I never understood radio wars, JR is cool, Futaba's Just fine, (usually what i use), and in my honest opinion HiTec is a Great company/
reciever too close to servos- excuse me for saying -- bull****
There is a reason why they call it "reciever" because it only recieves...
the commands it gives to the servos are not strong enough to cause any kind of interference.
My Feedback: (7)
Radio wars will continue, just like with cars, cameras, computers.
Human beings need to reassure themselves that they made a good decision.
It's important to be right. Often when you're growing up, a wrong decision can mean serious injury or death. So, as children, we all learn to like to think that we're making good decisions. Some of us never unlearn this. I know I didn't. I have the best car, camera, model plane, model plane radio, etc. If it wasn't the best, I wouldn't have bought it! I'm not telling you what they are because you may argue with me and convince me that I made a poor decision. I don't think I could take that kind of disapointment....
My Feedback: (7)
How enlightening... Need a bucket? I'll stick to my guns. Why do you think everyone thinks their engine is better than the other kind? Because it's better? Or because that's the one they bought?
NJ
you are all just jeleous because I have better stuff than you pirate: arrrrrrrrrrr
(is it me or are the emoticons getting wierder and wierder pirate: :tired: :sleeping: :bananahea :greedy: )
What a bunch of hooey. I buy things because:
a. I like it.
b. It was a good deal.
c. It will fit the application it is intended for.
I have a Magnum .28 on my combat plane. I certainly don't run around applauding myself for buying the best combat engine ever while guys with Norvels are zooming past me.
I am on my second JR radio. I bought the first one because it was on sale, and the second one because I wanted to be able to use the first as a buddy box (in my evil plot to get all of my friends hooked on RC). My neighbor has a 9C, and I recognize that while my 8103 and his are at about the same level of capability, his is a superior radio.
a. I like it.
My Feedback: (7)
JetSD,
You sound like me in this respect. Great. Not the most common attitude in this hobby. Surely you didn't think I was saying that we're all so insecure? Got your sarcasm detector turned off?
