Crashed my 1/4 Scale A-7 Corsair II
My Feedback: (33)
MS
I tried to do a loop on my second flight with this 108" 30lbs beast. On the bottom end of the loop at 3' off the ground I hit the only bush in a 3 block area. The guys at the field said that the bush died from being uprooted by the plane. The plane was still 3' off the ground stuck in the bush. The 4" spinner went about 30' from the rest of the plane. The wing was shoved a foot back in the fuse'. My wife was boiling mad when she saw the tape of the crash.
RE: Crashed my 1/4 Scale A-7 Corsair II
3' of the ground means 3 feet right?
Why soooo low, if you try some aerobatics for the first time with a new airplane go way up high, that way you have the time to correct if neccesary.
Too bad you lost it, it's quite a unique airplane I think, not much RC models of this one.
Bart
Bart
KY
Did you say tape? Is there any way we can see it?
Sorry about your loss but I love a good crash video.
Also, any chance of repairing it?
My Feedback: (33)
MS
I have not been able to find the taped footage. I started the loop at 300'. The plane weighed so much it dropped on the downward leg more than I realized till it hit the bush. My wife still gripes at me about this goof after 4 years.
ORIGINAL: memjsims
IMy wife was boiling mad when she saw the tape of the crash.
Why was she mad? it's not as if she has a real attachment to RC if she is not involved with it.
ON, CANADA
that is just too bad for ya man.....but all i can say is fix her up and put it in the air again......my plane looked worse than that when i put it into the ground.....and it was only a trainer..........[:@]
