Go Back  RCU Forums > RC Airplanes > Crash & Rebuild
 Finger problem >
Finger problem
Crash & Rebuild Post your crash stories, pictures and if you want to document your rebuild you can do that here too!
Finger problem
Old 08-08-2005 | 07:25 AM
Default Finger problem
I ahve a delta of my own design with TT 36 Pro and throttle pipe with a 8*8 prop that eats up the sky except this sunday when it bit the dirt and cartwheeled down the runway after a hand launch.
Moral of the story damb on of switch to close to hand hold result palne switched off on launch... result bust prop and leading edge to repair... good job I build em strong.....
Lesson learnt put the on of switch in a less vulnerable spot away from my big fingers.....
Old 08-08-2005 | 11:45 AM
Flyboy Dave's Avatar
My Feedback: (21)
Default RE: Finger problem
I did that once to a glow powered glider of mine....
....accidently turned off the switch at hand launch. (RIP) []
FBD.
Old 08-08-2005 | 02:26 PM
Bummer, sorry to hear about your crash. I've done the same thing at least once
Try installing the switch so that "on" is to the rear. Works for me.
Old 08-08-2005 | 11:43 PM
My Feedback: (21)
will....
....that's the problem. When you throw the plane, your hand moves the switch
forward.... to "off". []
Dave.
Old 08-09-2005 | 04:59 AM
Ok, let's hear it for a vertical switch
Old 08-10-2005 | 05:30 AM
Yep thats what I had a pull out for on and a push in for off...will move my switch out of the way....you fly you crash and you learn.
André
Old 08-24-2005 | 10:11 AM
hooliganflyer's Avatar
That happened to me asweal, with a thunder tiger ehawk1400, hand lauched it and nocked the switch. It glided well for a bit until the wind lifted the right wing and sent the thing into a tree, not much damage though
Bless the soft leafs
