GP Ultra Sport 60 re-birth
Looking good..
You did a better job of cutting away the wing sheeting than I did...
The fun part will be routing the retract control rods through into the center area....
Me, the more I thought about it, the more I realized the hastle it'd be. So I chickened out, I decided to stay with fixed gear.
Keep up the good work, and keep up the pictures. They're of good quality, easy to see details.
Thanks vmsguy, yeah sticking with fixed gear did go through my head that's for sure. But I have gotten this far so I will keep pushing through
![Wink](https://www.rcuniverse.com/forum/images/smilies/wink.gif)
I have epoxied in the retract rails after a long pain staking effort to get them both aligned with each other!!
Here is a pic of the fuse. Still have yet to do the tail design. My gradiose ideas for a covering scheme have disappeared and I opted for something a little simpler. I may get crazy on the wings but see how I feel
![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
Looks good...
I'm of the belief "Less is more".... When I painted my motorcycle, I removed every sticker, name plate, pin stripe.. etc. In my mind.. it turned out way better than I could've imaged.
I actually like the stickers on yours.. I've toyed with putting them on a bird, if tastefully done, like yours, they look good.
Why thank you vmsguy!
Engine is in! I simply cable-tied the fill line to the muffler line. It should make for easy filling![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
I previously used an APC 11x8 with outstanding results but like the look of the top flite power point props (same size/pitch). It seem a little smaller when you look at the width of the prop so hopefully I won't loose too much thrust. If I do I will stick the APC back on.
#31
Slowly getting there.
Retract servo is in, stab detailing done and I put a colour print out of a cockpit dash on there for good measure [8D] Have yet to decide how to style the fin - I don't want to repeat what is on the stab as that would be visually overpowering, something simple will come to me!
I didn't use any windex etc on the stab, just ironed on a low heat (2 on the tower hobbies iron).
#33
ORIGINAL: vmsguy
"Less is more"
Leave the fin bare...
I definitely have to work on mine tonight...!
"Less is more"
