Toledo Special
Toledo Special
I am reluctant to post this but Owell. I had a depth perception problem on saterday, ran my Toledo Special right into the only tree within 500'. Luckily I was on final approch so it was a low speed impact with the oak the plane came out of the tree with heavy damage to the right wings leading edge, left wingtip and both wing bolt areas. The fuse was damaged where the wing dowel rods mount, this area was riped off and the bottom 2/3 of the way to the tail. The fuse. is repaired except for the windshield and windows. I am happy wiyh the ease of repare of this Hanger 9 plane most of the glue joints and splices held, the firewall held and the landing gear is fine. I hope to have the wings fixed by next weekend as I am ready to fly her again. I wish I would have taken pics before I started but was so discusted with myself I did not think to. I am not very good at covering so do not want to post after pics ether. All in all I think the Toledo is a fairly rugged plane to have come through this without being a complete loss.
RE: Toledo Special
I thought I would post some pics of the wing rebuild but cant seem to, is there a tutorial on posting pics somewhere. Also the LHS did not have any monocoat that maches the colors of the Toledo very well I am most conserened with the blue but would like to return to the original colors some day.
RE: Toledo Special
The rebuild is comming along well some sanding ant still have to fix the wingbolt area onthe left wing. I should be ready to cover soon. Still looking for a match for the colors.
RE: Toledo Special
First two flights after crash went well. She is not quite as pretty as before but flyes the same now looks like a daily beater if the weather holds out tomarrow I will ring it out a bit more tonight was like a maiden flight to me.
RE: Toledo Special
Hi 417mack
You mention that your depth perception failed you. Why don't you Google depth perception and post what you learn. Depth perception had nothing to do with it.
RE: Toledo Special
ORIGINAL: Villa
Hi 417mack
Hi 417mack
RE: Toledo Special
Many R/C fliers believe that their depth perception works for hundreds of feet, and will not believe that our human binocular vision is good for only about 17 feet. At a few hundred feet, we humans cannot tell what item is closer or further away. All we can do is give obstructions plenty of room. Come over obstructions very high. Try to touch down right in front of you. That is the only time you know where the plane is relative to the runway, and more important, know it is at a safe air speed. Lots of practice will get you there. I normally would not answer you since you chose to go with little respect. I hope I am not mistaken in this exception.
RE: Toledo Special
Villa, I answered the way I did not out of a lack of respect but did not like what I thought you were implying, maby I tookj it a little personal. I know it is hard enough for two strangers to communicate standing next to each other mutch less 900 miles apart. I used the term depth perception as a short explnation for what happened. I have had many sucessful flights on this same pattern at the same field mostly in the evening , the mishap happened at12:30 I wanted a long low glide in and made it a little to long, a mistake I will try not to make again I think the sun directly over head and the cooler temp giving the engine more power helped me make this mishap but maby not. I realize what you are saying about binocular vision but I can judge yardage pretty well out to 600 yrds +/- 10 and much farther if there are objects withen the plane to work the distance out I know this because I have compared my estimations with the known trajectory ao a 22-250 in northwestern Texas with good results. With a plane there is only open sky but the tree in question is not that far maby 350 yrds.
RE: Toledo Special
Hi 417mack
The problem is that most R/C fliers do not realize how blind they are when flying their plane. Let's refer to that tree at 350 yards from you. If your plane is flying from your left to your right, near the tree, will you pass the tree in front or behind the tree, or hit the tree. There is no physical way for you to know that. You have to proof this to yourself. Mark a spot 350 yards away from you and try to land on it, approaching it from various angles. With practice you can get better, but if you then change the angle of approach, or the wind changes in intensity and/or direction, you will be lost again. An additional problem is keeping the plane above stall speed during the landing. Changing the angle of approach relative to the runway and/or wind direction and/or intensity can put you in a surprised stall. I have had many hundreds of crashes and have always tried to figure out the reason.
RE: Toledo Special
I agree compleatly my propblem was not compleatly a vision problem but several misjudgements combined and I will probably do this again but not in the same spot and hopefully not the same circumstances and ofcorse not when there is a chance to damage life or property.
RE: Toledo Special
Hi 417Mack,
Covering for the Toledo Special along with parts and pieces can be found on Hangar 9's web site. The covering is Creme, PN HANU878 and Sky Blue PN HANU875. I have to have inherited a crashed Toledo Special and am in the process of making repairs.
Good luck with your plane!
Best Regards
Carlos G.
Best Regards
Carlos G.
RE: Toledo Special
Thank you Carlos I found the part # while looking for a new windshield. I think I will recover it This winter. After several flights it seems fine but is a bit heaver.
