Cloud Dancer does not make a good wheat combine
1 Attachment(s)
Finally really beginning to like this plane and look what happens! I had a brain disconnect between the head and the thumbs. Funny how when your inverted and you pull a little up elevator and realize it's the wrong way that pulling more up elevator doesn't help the situation at all!!! :D
The story that I am sticking to is that the farmer was behind in his harvesting so I thought I would give him a hand....... :p or It's the first plane that I put in.....I had to get it out of my system sometime...... :rolleyes: I am looking for another one of these if anyone has one they are looking to sell. |
and a close up
1 Attachment(s)
Still have to check to see if the engine survived....It is currently packed with dirt! :(
Hey that doesn't look totally destroyed. :rolleyes: A little bit of CA here and there and she should be as good as new. Are you planning on repairing?
hei that plane can still fly.
the wing just need a little bit of ca and maybe some ribs need to be changed. the fuselage looks good... do not trash it....if u want to, send it to me!!!!!hehe |
No send it to me! lol :D Why fix a crashed plane when it will only crash again? If you need to replace the ribs and don't have the plans for reference, could you manage to use CA debonder to remove a good rib to use as a reference if the other ribs are trashed? Are there any repair tips or info around on the net? :confused:
Hey, I've been posting and I am now a "member" and not just a new friend. How exciting. :p
CONGRATULATION MAN.
wow...you are a member already????? make sure u remember this day...then we can celebrate your anniversary next month this same day as your 1st month as a true 'member' hehe.;) oh yeah i'm sure there are tips on the net for repairs..go around this website...go to the construction forum or the tips or the beginner or anywhere else where u might think there might be something... |
Certainly repairable. Might take 30 to 40 hours to do it right, but if you had to build a new kit....
I assume this was an ARF, and you want to replace it with another ARF. How long did it take to put together initially? How badly do you want to learn how to build (repair)? How much money do you have to throw at this stuff? All questions you should answer before you proceed. ;) Dennis- |
cloud dancer as a combine
Still haven't decided whether I will fix or forget this one. It was an ARF that took about 10-15 hours to put together. Believe it or not it was my first plane after the trainer..........didn't like it then. After flying the wings off of everything else I could get my hands on I finally decided I really like the plane. Everything was really smooth nothing jerky or out of control looking, just a nice flying - nice looking airplane.
There is A LOT of internal fuse damage, the pictures don't do justice to what is actually seen inside. Basically everything that could pop loose inside is loose. It will probably just turn into a wall display, I am considering cutting the tail off and mounting it on the wall as if it went through....he he :p Still have to see if the engine survived...hope so. It was just starting to really run good. Maybe 30 flights total on it. |
I think I would try to repair it. Thin CA can do wonders on cracked but still perfectly fitting pieces.
It will probably just turn into a wall display, I am considering cutting the tail off and mounting it on the wall as if it went through....he he |
Lol really, that is awesome, my mom would probably kill me if I did that.
yeah then when u need a replacement elevator you just have to 'pluck' it out of the wall!!!!!
I need to start my own "trophy room". Right where everyone can see it, in the family room. Family room, "trophy room"; they go together don't they :confused:
1 Attachment(s)
I have this same plane so I feel your pain. Mine hasn't flown yet so lets hope history doesn't repeat itself. Good luck if you try to fix it.
I don't know. I once had a History teacher that said history always repeats itself. I must of heard that the one day I was actually paying attention. :)
flyerdarren
You will love the plane, it is such a fine machine. Everything is very smooth and very controlled, I found no bad tendancies to it. I will say that if you are not comfortable landing a bit on the fast side you may have to work with it a bit. It will glide in ground effect forever if you let it, so I found that with a little hotter landing it was perfect. One word of caution though, upon landing DO NOT pull any up elevator until it is almost at a stop or it will jump back into the air on you :eek: ......been there - done that! :p When looking down on plane make sure your landing gear is forward enough to see the atleast 1/2 the wheels infront of the wing or it has a really really bad tendancy to be very light in the tail and will nose over while taxiing on a grass runway. By the way if you decide you don't like the plane for some reason feel free to pack it up and send it to me, I would be more than happy to give it a good home! :D |
hopefully it will fly this weekend if the weather holds out. I'm running an FMA co-pilot in it and i might try to rig it for video if it's as smooth as i hear.
Flew my CD this last wekend, Man I can see why you liked this plane. It is sweet. If I you were you I'd be ordering another one right now.
:D :D :D :D :D :D :D after flying darren's the other day... i now have one in the mail!!! (my wife is gonna kill me :( )
I knew you would like it, seems that everyone that flew mine really liked it. I have been contemplating the ordering of a new one, however, I do have a TT champion 45L which is a very similiar airplane by design but only a 46 size. I also have a U CAN DO 46 with a brand new Saito 72 both of which need to be put together.
Boy do I miss that Cloud Dancer though.......... |
| All times are GMT -8. The time now is 11:33 AM. |
