NEED HELP,HELP,HELP
Hi Jamie
May I ask you a question?
When you ask a question on a post, are you expecting someone to be monitoring the posts 24/7?
Every now and then, I see large corporate website that maintain a trouble shooter on-line, but normally here in the RCU forums, these posts are monitored by volunteers. Some areas are more active than others.
However, I see that echobot has responded to you? Did you follow up on that at all?
If that turns does not turn out to be an OK answer for you, PM me. I'll do some research for you,
marwen
marwen
AR
How about a dumb question. Do any of the wires from the camera (kx191) or the transmitter ( 900MHz - 500mW) have to be shielded? the connectors weight more than the equip. I got extra plugs so I can maybe make my own wires and solider the connections for less AUW.
Thanks for your help, just learning. Mike
