How many pics?
Just how many pics will a 4gb memory card hold at 10mp?
skeeter |
RE: How many pics?
I use 8 GB cards in my Nikon D60, and on the second highest quality setting (with picture sizes of 3-5 mb each) I can get around 2,000-2,400 pictures. So you should get approximately half of that. But that's hard to predict because the quality settings of the pictures you are taking will determine how many you can get. The higher quality pictures mean larger file sizes which mean less pictures on the card.
Hope this helps Ken |
RE: How many pics?
If memory was not an issue would it be best to take pictures at the highest quality and then use your computer to resize as needed?
skeeter |
RE: How many pics?
Yes indeed that would be the best plan. Also refrain from using digital zoom as that can also be achieved on the computer when editing. In answer to your first question, Ken is correct about the quality affecting the size of the image file. Also the camera may have settings to save as different file types. Different file types have different compression algorithms. You might have seen what happens on your computer when you save a bitmap (.bmp) file as a jpeg (.jpg). The jpeg may be half or even smaller than the bmp file. Another attribute affecting file size is the complexity of the image. Take a photo of a clear blue sky and a photo of a heavily textured surface, say lawn. The image sizes will vary greatly due to the complexity of the image.
I have a 10 mega pixel camera and most photos are around 3mb in file size. On a 4gb card (which is 4,096mb) I could fit 1365 images. |
RE: How many pics?
ORIGINAL: skeeter_ca If memory was not an issue would it be best to take pictures at the highest quality and then use your computer to resize as needed? skeeter Ken |
| All times are GMT -8. The time now is 08:29 PM. |
