Q about draganflyer V Ti Pro built in receiver
Hi,
Is the built in receiver in the Draganflyer V Ti Pro compatible with both 35mhz and 72mhz freq band?? Thanks in advance
RE: Q about draganflyer V Ti Pro built in receiver
hmm might have to ask the manufacturer, but i cant find there contact details on there site!
Hi, no the reciever is not compatible, it needs modification to make it work at 35 (36?) Mhz. In Australia it's not compatible with the local frequency (36), but I have not modified mine yet, it seems as though adding a small external reciever unit and disabling the origional one would be easier than the tricky (and apparently not very satisfactory) conversion.
oops, just noticed you were talking about the Pro version, not sure if that uses an integrated reciever or not.
ORIGINAL: j_js1
Hi,
Hi,
The reciever is a dual-conversion NBFM MC13135DW (see http://www.datasheetcatalog.com/data...C13135DW.shtml )
Assuming you already have a 35 Mhz Transmitter, there are only 4 components that need to be changed (possibly 3)
1: The quartz= frequency -10.7Mhz
2: condensators over/to the 2 coils on the bottom should be larger capacity by soldering extra capacitor parallel to them, this will shift the resonanse frequency downward.
3: longer Antenna
(4: maybe the coils need to be replaced, but most of them have a broad range depending on the capacitor and the core position)
I could not find the data on the coils used, other then they are probably mitshumi. so i can't give the values for the condensators.
Hope someone picks this up, i'll try and do some more research.
