D\F modification
D\F modification
Hi all
I am thinking about build a new x-frame from C\F and use 4 GWS motor GW\EPS-300DS prop 11X4.7
What do you think? I want to use the VTi board
Moti
http://www.gwsus.com/english/product...em/eps300c.htm
Moti
RE: D\F modification
ORIGINAL: msarid
Hi all
Moti
Hi all
Moti
Mike
ORIGINAL: Old Man Mike
The x-frame is nice but I doubt you will get that motor to work with DF. 4 of those motors with that prop will draw over 20 amps for the voltage output from the controller. I'm assuming that is a brushless motor which is a somewhat difficult redesign task (see brushless motor thread).
Mike
ORIGINAL: msarid
Hi all
Moti
Hi all
Moti
Mike
This is not a brushless motor, the motor is the same brushed motor as the D\F (i have one) the gear is 6.6:1 close to the D\F gear.
we can find in the site(http://www.gwsus.com/english/product...em/eps300c.htm) a set that can match the D\F board.
the GWS is more rigid and can reduced the motor vibration and the prop hitting the frame.
Please advise
Moti
ORIGINAL: msarid
Hi mike
Please advise
Moti
Hi mike
Please advise
Moti
Hope that helps,
Mike
