E-Flight Power Sources Ask questions or read about power sources as they specifically relate to e-flight including Lithium-ion, Li-Poly, Nimh and Nicad battery packs.
Johnson Motors
Old 12-27-2003 | 07:02 AM
Default Johnson Motors
Has anyone used the Johnson Motors ? I have heard of a set-up, using a GWS 100 drive, With the high Ratio gears 6.? : 1 and this Johnson motor from ALL ELECTRONIC 6.v motor about the diameter of a 270 Mabuchi motor with flattened sides. This motor cost .50 cents; YES Half a Buck ! and in this drive people are saying it will get 1/3 more power, and still stay under 5 amps.
I'm waiting for the drives to come in so I can give it a shot.
Check out ALL ELECTRONIC.COM real cheap motors and other stuff.
Old 01-04-2004 | 04:28 AM
Default RE: Johnson Motors
I got my GWS 100 drives in and changed the motor to a johnson motor. This set-up is a screemer! 12x8 prop it seays under 6 amps and pulls better than a 300 drive.
n bobbdd
Old 01-17-2004 | 01:26 PM
Epoxy Cup's Avatar
I'm no expert but I bought 6 of the All Electronics motors and built a little 26" wing. Direct drive with GWS 3x3 prop (I think). It screams. Oh yes I use 2 cell 1200 LiPo.
Old 01-28-2004 | 10:13 PM
bobbdd, I have been trying to locate all electronic.com, but havehad no luck. I'd like to check these motors out. Do you have a link?
Bud
Old 01-28-2004 | 11:04 PM
PaulVi's Avatar
http://www.allelectronics.com/
Old 01-28-2004 | 11:08 PM
Here is the ultimate thread for you!
http://www.rcgroups.com/forums/showt...Johnson+motors
Cheers, Phil
Old 01-29-2004 | 08:09 AM
Thanks for the link! I'm gonna try a few out and see what happens.
Happy fling!
Bud
