Power pack selection
I built an old Pilot kit of a 42" Mustang. Converted it to electric and put in a 15 sized Astro geared cobalt. Have a 12 cell Nicads pack in it but have never tried flying it. I used Electricalc program to set it up and got it to come in at the original wet weight of 43/4 lbs. I would like to drop as much weight as possible and try to keep a duration time of 10 -12 minutes if possible. I appreciate any help as my brain trust hit full with Nimh info and I can not cram any more battery theory in. RobertV
My Feedback: (21)
What cells is the pack made from? This is important, because it will tell us whether you can save any weight by going to NiMH, using a smaller cell.
According to the AstroFlight website, the geared Astro 15 cobalt draws about 24 Amps on 12 cells with a 12x8 prop. I take it that this is about where you are? Max current for the motor is 25 Amps, and you don't want to push Astro motors beyond their specified capabilities for long.
On a plane with full Sub C cells that draws less than 40 Amps, you can replace the pack with a pack of HR4/5FAUP cells. This will give you approximately the same weight as LiPoly, without the issues LiPoly brings to the table. On 16 cells, its a savings of 8 ounces over Sub C cells, so I'd expect you'll save about 6 ounces on a 12-cell pack.
Astro says 325 Watts. With the lighter cells, about 4-1/2 pounds. That's 72 Watts per pound. It'll fly "scale-like," not real fast. Climbs won't be that great either.
