etech 2 cel li-poly & piccoboard.......
I've got an etech 2-cel li-poly on the way (throwin out that low powered, boat anchor of a stock battery for the Eco piccolo lol)
I've read several times that you don't want the voltage on a 2-cel to go below 6 volts. (3v per cel)
The Piccoboard on my heli shutsdown the main prop motor when the voltage gets low enough
from the stock battery.
is this low voltage auto shutoff on the piccoboard going to happen at or around 6 volts left in the 2-cel??
I'm concerned if i run this new battery down on the picco it might damage it below the 6 volts.
or am i worried about nothing at all?
thanks in advance.
thanks in advance.
