E-Flight Power Sources Ask questions or read about power sources as they specifically relate to e-flight including Lithium-ion, Li-Poly, Nimh and Nicad battery packs.
tp340 parallel charging
Old 05-01-2004 | 08:31 AM
Default tp340 parallel charging
I just bought 2 thunder power 340 mah packs. I wired them in parallel on a y harness.
I charged both of them seperately the first time.
What is the best way to charge from this point on...as one pack or two.
Thanks for your help, greatly appreciated
Jeremy Davis
Old 05-04-2004 | 05:03 PM
enrique1123's Avatar
Default RE: tp340 parallel charging
You can charge then in paralllel so long as the voltage is the same when you connect them together. If one of the packs has more voltage than the other one and the difference is big enough you could end up ruinning both packs.
