charging 6 volt Rx battery
RE: charging 6 volt Rx battery
What is the capacity of your 5 cell pack? you should be able to charge it on your reg charger, if the capacity is lower than 700 i would plug it in to the RX side of the charger , if its over 700mah use the TX side of the charger.
This explains it http://www.rcbatteryclinic.com/wallwart.htm
