E-Flight Power Sources Ask questions or read about power sources as they specifically relate to e-flight including Lithium-ion, Li-Poly, Nimh and Nicad battery packs.
Apachee and 3s li-poly
Old 09-20-2004 | 04:45 PM
Default Apachee and 3s li-poly
I've got an Apachee 2500 li-poly charger that works great on E-TEC 2s 700. I wanted to start using some 3s batteries but have heard some rumors that the Apachee 2500 won't charge them once their below 10v even though this is still a normal operating range for the battery. Is this true, or just a few bad cases? thanks!
Old 09-24-2004 | 05:08 PM
Default RE: Apachee and 3s li-poly
Only if the pack gets a cell imbalance from being stored in a discharged or partially discharged state for a long period of time.
Rule is : once you get home from flying, charge the packs up immediately.
My Apache works just fine when I stick to the above rule. Good luck.
