E-Flight Power Sources Ask questions or read about power sources as they specifically relate to e-flight including Lithium-ion, Li-Poly, Nimh and Nicad battery packs.
lipo volt watch
Old 12-19-2004 | 07:23 PM
My Feedback: (15)
Default lipo volt watch
Hi Folks,
I `m sure that this has been discussed many times ,but what is the most common pratice among lipo users to make certain that the cell do not drop below 3vs? Do most people take short flights and then do v check with a watt meter, or is there custom esc used just for lipos that shut the motor off at 3+ volts.
thanks ,
Frank
Old 12-20-2004 | 09:37 AM
My Feedback: (20)
Default RE: lipo volt watch
ORIGINAL: skrez
Hi Folks,
I `m sure that this has been discussed many times ,but what is the most common pratice among lipo users to make certain that the cell do not drop below 3vs? Do most people take short flights and then do v check with a watt meter, or is there custom esc used just for lipos that shut the motor off at 3+ volts.thanks ,
Frank
Hey Frank
Most ESC like Castle Creations ESC can be programed at different cut out/off voltages. Others are preset.
You can down load the manual from here > http://www.castlecreations.com/
HTH
Old 12-20-2004 | 12:53 PM
My Feedback: (15)
Doug,
Thanks fir that info, that helps me alot.
Merry Christmas
Frank
