TP Packs in series
TP Packs in series
When running two packs in series, is it necessary that each pack have the same voltage to start, and if they are not, how do you correct the situation? Bill Hunt. I am runnin two TP3s2p 4200 in series
My Feedback: (27)
RE: TP Packs in series
TP recommends they be within .01 volts of each other. You can use the same charger to charge both or I just hook them in parallel after charging on seperate chargers till they equalize, seems easier to me. You'll need a decent dvm.
